selimum speaker
slamin87
ok guys a local shop salen these Selenium 6W4P for 18 bucks brand new and the 8inch ones 22 bucks each are these worth puting in. i was thinking 4 of the 6inchs and 4 of the the 8inchs for the rear deck and if i do get wat would i run on the amp full/low/high confused on that thanks
well, parts express sells those for the 6 inch woofers for 32 bucks, so you are getting a deal, i woulnd't mix the 6 inchs woofers with the 8 inchs, not worth it imo, and at a rated 100rms each set your low pass, to around 100 hertz
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
cool man thanks for the advise on them anyone know a good crossover i can use with them ?
I use both the 6 and the 8 in my setup, and with the right amount of processing they do very well. I would strongly suggest running them in an active processing setup.
to be honest with you i dont know the difference with active and "passive" if that what regular crossover called can you explain so i get better understanding of the active thanks
Active means that you are actively controlling each driver typically with a digital EQ of some sort. Passive means that you will use a preset crossover device. Like the ones that come in a 2way component set.
From my experience, a passive xover really limits you in setting up these drivers successfully. They are pretty efficient in certain bands and can get out of control very easily. This is why you will hear people say they sound like crap just like all other pro drivers, when in fact they have just been set up wrong
thank you ok so you think this would work http://www.sonicelectronix.com/item_6655_Clarion+EQS746.html
put at least 100w to them and they will sound great
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1389 Guests (See full list)
