KckrL5s Posted August 19, 2007 Report Share Posted August 19, 2007 A friend came over couple days ago with a problem. He has an old pioneer amp(200watts), he said it was his power wire(4ga to dist.-8ga to amp) I checked it and looked over the rest of the wiring all good. His amp will light up for 1-2 secs and then it will dim and start blinking. His amp is grounded between the seatbelt end and the seat rack that looks like it attaches directly to the body, could this be the problem?? 2009 spring fling-iasca-rookie 1-Champion. 139.4db. "I don't do enough, I just fool around Ya'll can go to hell, how does that sound"~ Tech N9NE 4 15" Memphis. and 1 Big ass box. <-Sold to fund more power. Kicker l5s Link to comment Share on other sites More sharing options...
roscoe1129 Posted August 19, 2007 Report Share Posted August 19, 2007 Probably, that is the worst place to ground to. find an area grind the paint off and attatch it the the bare metal. When you use an existing bolt or seatbelt type bracket screw that shit is protected against corrosion which means its covered in crap causing bad connection. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
Coolwazabi Posted August 19, 2007 Report Share Posted August 19, 2007 it could be a problem if its actually bolted something like onto paint insted of bare metal.. and sounds like maybe the gains are set accordingly and its going into protect.. Link to comment Share on other sites More sharing options...
KckrL5s Posted August 19, 2007 Author Report Share Posted August 19, 2007 Thanks guys. 2009 spring fling-iasca-rookie 1-Champion. 139.4db. "I don't do enough, I just fool around Ya'll can go to hell, how does that sound"~ Tech N9NE 4 15" Memphis. and 1 Big ass box. <-Sold to fund more power. Kicker l5s Link to comment Share on other sites More sharing options...
roscoe1129 Posted August 19, 2007 Report Share Posted August 19, 2007 it could be a problem if its actually bolted something like onto paint insted of bare metal.. and sounds like maybe the gains are set accordingly and its going into protect.. Once again check your ground. a blinking amp is a sure sign of your ground being bad, not being in protect mode. In protect it will power up and the led turns red instead of green, but still is on not blinking......... Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
