not the overflow tank... on eachside of your radiator there might be plastic tanks . and were the tanks and the rad come together is where mine leaked at. kinda hard to explain lol. yours might not even have them mine did on my s-10 jus throwin it out there
I checked I don't think I seen any type of tanks on the side thanks for the info tho.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Scratch that I do have plastic tanks on the sides of the rad and they have little tabs that hold them on.
I looked and looked but I didn't see no cracks or anything on the front where I can see it but the back I couldn't really see crap.
so when you look at the reservoir(s)...are they at the full line or what?
When it starts leaking, run your finger and try to find the highest source that is wet. Look around that area.
Eclipse cd7000
might be the core when you flushed it might have removed some of the dirt in the radiator and opened up the leak if at all possible pull the radiator plug the outlets and pump some air into the fill hole and dunk it in water to see if you can find any bubbles
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Thanks for that but won't be possible right now.
I need like a quick fix option.
Edited by Rebel4055
Water pump leak? Thermostat gone bad?
Edit: Leave the car on and let it run. It tends to cool down if you drive it so the leak doesnt show up when you get home. So let it run for a few minutes in park and look undernneath the engine to look for that leak. Pinpoint where the leak is dropping on the floor and the see if you can track it.Quick fix is try one of those stop leak for the radiator and see if that works.
Edited by raolito1980
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
Alright does anyone have any experience with that stop leak product?
stuff that you put in and it glows under a uv light where you have a leak? that stuff? or am i thinking of something else?
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
