Universal Window Kit
So, does anybody have experience converting manual windows to power? I need to rebuild my doors and door panels and would like to not have a window crank anymore. It's on the sausage, a 93 Sonoma. While I was at it, I wouldn't mind doing power locks as well and integrating a newer alarm.. I have a couple vipers...a 5701 and something else. I could go ahead and shave it too, no problem..
I was looking at the above kit... I don't mind going more expensive, but I couldnt find anything that looked much better.. I looked at autoloc, and a couple other sites too.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
Well I've done a few cars and trucks in the past but I've always used OEM parts. You can go to a junkyard nearby and pick up everything you need from a truck like yours. Motors, relays, switches, mouning brackets, and even door panels. I don't know your truck that well so I'm not sure it's a direct swap but every Honda or Toyota I've done was.
It should be a direct swap but junkyards are tough out here and it is even hard to find s-10 parts on craigslist... I still have an ear out, but want to keep my options open.
  • 2 months later...
I've done a lot of converting from manual to auto Windows amd locks. The kit I use is spal. Motor is quite and works very well. Crimestopper has some cheap door lock actuators that I use. U can get a dei451 m which is used to wire up the door locks. Or if u are familiar with hooking up relays u will need 2 and wire it 5wire.
  • Who's Online   0 Members, 0 Anonymous, 3257 Guests (See full list)
