i looked at one of the other forums where you had the power listed for the new 1500 and the pics my question is will the amp push about the same rms wattage as the old version or will it put out more at 13 volts. the v1 in the clamp test on here is listing 1900+ watts and your other listing was only tested for 1540wrms. So will the new one put out more power than that
It was about 16% more power head-to-head under identical conditions at 1 ohm nominal after rise.
The official clamp test thread was conducted at 0.5 ohm nominal -- therefore more power was seen.
I would expect the different to be a bit smaller at 0.5 ohm, around 5-10% or so -- as the improvements to the 1500D v.2 were centered around the most gain in a daily system wired to 1 ohm and also to reduce size and further improve durability.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
