wjames104 Posted December 1, 2010 Report Posted December 1, 2010 Is there any chances that I can push a 15" Fi SSD Dual2ohms sub using a Rockford Fosgate Punch P400-2 amp? through a 4-ohm bridged mode connection.
wjames104 Posted December 1, 2010 Author Report Posted December 1, 2010 I hope Steve can answer this post asap ,I am thinking of buying an SSD next week! thanks in advance Steve!
Guest Posted December 1, 2010 Report Posted December 1, 2010 steve is pretty damn busy but ill be more than glad to answer your question. i wouldnt use that amp with an SSD because its not enough power. i recommend getting an amplifier that can output about 800-1000 watts rms at 1 ohm.
Skullz Posted December 1, 2010 Report Posted December 1, 2010 Yes you can but you'll want more after a short time using it though, i would think about getting a larger mono amp for it. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
wjames104 Posted December 1, 2010 Author Report Posted December 1, 2010 Hi there Kranny and Skullz! Thanks for your quick response!
Skullz Posted December 1, 2010 Report Posted December 1, 2010 If that happens to be the only amp you have available at this time to use you'll be fine till you can afford a sweet amp to power that thing with. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Guest Posted December 1, 2010 Report Posted December 1, 2010 If that happens to be the only amp you have available at this time to use you'll be fine till you can afford a sweet amp to power that thing with. yes. if by all means you dont have enough money for a bigger amp, the p400 will work. dont get me wrong haha. that thing will just be itching for more power.
wjames104 Posted December 1, 2010 Author Report Posted December 1, 2010 Thank you for all of your inputs!
