running power wire through passenger side - need help
The idiots at the car audio shop ran the power wire down the drivers side where I had already ran remote and RCA.
So now I'm going to run the power down the passenger but I'm not sure where to run it.
There is a small hole near the feet place on the passenger side but I had trouble locating it from the engine compartment and under the car.
They used some little wire thing to trace it when they did it, but the drivers side looks a lot easier to get to.
Any suggestions?
Also, would 0, 1, 2, 4awg wire fit in the panel between the door? The 8awg I have now seems like it just barely fit...
1996 gmc jimmy 4x4 SLT 4 door.
Also, suggestions on where to run everything also welcome.
i suck men dry...email me for details
I ran mine on my 99 blazer under the blazer to the back and went up under the back seats in to my bat
1. where did you run it exactly? (or would it even matter?)
2. what did you use to protect the wire/secure the wire?
I will probably do this if I get bigger wire. Just wanted to see if the electrical interference is being caused by the power wire being next to the rca cables
1.down the passenger side along frame rail but u can run it how ever u want
2.I used thick zip ties and I used nothing to protect it but u can use a peice of PVC if u wanted
3.it probally is interfering a lill but not to much if it's only a 8ga wire I would just re run the rcas then it woul be easyer
on the passenger door, where there is a rubber / plastic tubing tht holds the wire to the window controls and power locks. u can run the wire in tht hole that should be under the dash/ glove box but on the side.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
  • Who's Online   1 Member, 0 Anonymous, 1417 Guests (See full list)
