VW Golf Mk3 1996 Build From England
Every wire so far has been soldered and heatshrunk
And the right speaker (obviously the same as the left)
And these are all the bits of trim I had to take off:
My headunit needed an adapter for the radio:
2/6/2010
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
I also found a fusebox at a place I was doing gardening for:
Got me some fairly thick wires and a dual input 100A breaker - ideal for two of those batteries in the boot:
Finally my exams finished and I could get on with finishing my build
Got the paint for the box
MDF Primer from Homebase (my friend works there so he got a discount)
Metallic blue paint £3 from Wilkinsons
Grey Fleckstone £7 from B&Q
Filled in the screwheads with woodfiller
My friend doing some sanding
I put my on/off switch in a space next to the headunit
Ran the RCA lead, bass remote knob cable, on/off switch lead and a spare
Finally got my trim back on
I spent quite a long time like this
Priming
Standard issue cut – just from rubbing the paintbrush up and down inside the port
Second coat of primer
Late night grey primering
Rocking the flip-flops!!
Ran out of grey primer so I did the port black (holding a spray can in a port is difficult)
Fleckstone:
This ran out after 2 sides
29/7/2010
Not going to run out this time!!!
Old battery terminals:
New ones from chicane:
I like gold
Here is the battery
Looks like a good spot for the bass knob,
Just get rid of that…
Little bit of hot glue
Ow
This is the spare wire (I may put lights in the boot or need a switch) so I taped it to the back of the blanking plate next to the on/off switch for the amp
