VW Golf Mk3 1996 Build From England
Finished control panel
30/7/2010
Neutrik Speakon Connector
Close up of the fleckstone
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
Found a foam ring, cut it for a better seal for the sub
This is seriously heavy to lift. It is 1” MDF with a 2” baffle
Made some terminals for the trip switch by cutting some copper pipe and crushing it in the vice
Got some MDF for free (a guy I was helping clear out his garage gave me them)
Looks like a battery plate and fuse holder can be made – lets get creative
Cut a small length off the original DIN rail
I cut some notches to stop it sliding around
Cutting the battery board:
Making a frame to go round the batteries
One ropy bit of jigsawing later…
I also put a strap over them by drilling a hole to let it through
Little of the old PVA
31/8/2010
Got heatshrink?
Ah – the wire I got from the fusebox is a bit too big for my flat terminals.
So I put the middle in and soldered the rest to the outside then covered it with heatshrink
First time soldering with a butane torch
Here is the wire (thanks Karl (B-Chi), Simon (BRAVOHGT) and OvEr_KiLL)
SPL Dynamics 0 gauge
Voodoo 0 Gauge
No idea what make but its enough to go from front to back
Also a few bits of 4 gauge and 8 gauge
My amp from Simon (BRAVOHGT)
It’s a Voodoo monoblock 800.1
Specs:
http://www.voodoocaraudio.co.uk/productsAmplifiersV8001.html
My sub is dual 4 ohm wired down to 2ohm so it is putting out 500W RMS
My ring terminals came from darvex.com
I got all these delivered for about £20
Also bought some bolts, washers, nuts and wingnuts from Screwfix
The battery clamp happened to have an 8mm bolt – a perfect place for upgrading my battery to chassis ground
