VW Golf Mk3 1996 Build From England
Add a drill and a wire brush wheel:
First time soldering 0 gauge!!
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
It’s the return of my helpful workmate Oscar
The grey 0 gauge already had a terminal at each end so I decided to leave them on and use it for the ANL fuse. But of course I cant just have a wire crimped so I filled them and a connector in the middle with solder and then put heatshrink over it
I ripped my hands raw pulling the heatshrink down 3m of cable – especially as there were some bits which had had duct tape on them and were sticky as a result!!
Soldering the grey positive wire
And the blue grounding wire
Grounding location
Add an 8mm drill and the wire wheel treatment
The amp came with some sticky foam feet protectors and some screws
Making the fuse holder and buss bolt holder
I drilled a hole through, then used a butterfly bit to make the hole a bit wider, put the bolt all the way through and covered the head with wood filler.
Glued
And screwed
Running the grey positive wire
This is the handiest tool in the world for pulling wires through
Soldering the 4 gauge from the buss bolts to the amp
Checking for length
And snip
Tidying up wires
Making negative battery cables
And the short positive run from the trip switch to the positive buss bolt
And the finished thing
From above
My view in the rear view mirror
My control panel
Difference between completely empty and with the sub, box, amp. Wire and batteries in:
And full
(I thought it would be more than that)
Well there you have it. This build has taken a long time to complete. I have been listening to it though in between – first I had my dads 200W amp running off one of the 17ah batteries (which I had to change at the end of every journey). Then for T-18 I lashed up the new amp with 8 gauge wire and it did 135.4db!! It has been a great experience and although I’ve finished it 2 weeks before I go to Uni I will still have it for when I come home.
The best part about this build has been the money ive saved and the knowledge I’ve gained on the way. All in this build was just under £300 which is thanks to buying second hand and careful browsing
Thanks for taking the time to read this. Some people may think I have too many pictures but this is exactly how I learnt everything I know – from reading hundreds of build logs and watching thousands of youtube videos. It was Steve Meades videos that got me really interested in car audio and I hope to have a system to rival his someday
Thanks to Matt Sprigg and Am Singh whose massive builds inspired me
