tip n tell Posted December 8, 2010 Report Posted December 8, 2010 I have a 95 civic hatch with 2 -240amp 3g alts external adjustable regulator. Would like to know if I can run the 2 off the same regulator. I want both to work in unison. So if I put the 2 stator wires together, and the field wire together, from each alt then to the regulator.... all good right? Oh and it can run 30amps to the field (rotor}.Can this be done? No warranty 95 civic air-ride RE-5 slam specialties 4-18's Dc xlm2's tuned 35hz 2-1100.1's @ .35 each 2-SD 250.2 nano amps 3-deka 9a31 1-deka 35ah 2-250 amp alts/ Adjustable regulator 159 sealed @ dash 51hz
Guest DC Power Rob Posted December 8, 2010 Report Posted December 8, 2010 Theoretically, yes, but in practice it doesn't always work as you would think... You have to remember, the regulator has to react REALLY fast to control 2 alternators.. It will either be really jumpy with big voltage spikes, or really laggy trying to catch up with the 2 different alternators.. They wont split the load equally as well as you would think.. Not trying to discourage you from doing it, but 2 alternators with internal regulators will control and cooperate better than 2 alternators on a single regulator..
JaM Customs aka mprete Posted December 8, 2010 Report Posted December 8, 2010 agreed^^ 2001 dodge ram 2500 quad cab 5.9L V8 my build logs... dodge build http://www.stevemeadedesigns.com/board/topic/94914-mpretes-2001-dodge-ram-2500-quad-cab-build-log/ trik build http://www.stevemeadedesigns.com/board/topic/94447-trik-build/page__p__1298547__hl__trik__fromsearch__1entry1298547 box building thread- very cool designs (PICS!!!) http://www.stevemeadedesigns.com/board/topic/95713-2d-or-3d-box-pics/page__gopid__1318152entry1318152 i am a mechanic, pm me if you have questions or anything.
tip n tell Posted December 8, 2010 Author Report Posted December 8, 2010 Theoretically, yes, but in practice it doesn't always work as you would think... You have to remember, the regulator has to react REALLY fast to control 2 alternators.. It will either be really jumpy with big voltage spikes, or really laggy trying to catch up with the 2 different alternators.. They wont split the load equally as well as you would think.. Not trying to discourage you from doing it, but 2 alternators with internal regulators will control and cooperate better than 2 alternators on a single regulator.. ok, but with 2 internal regulators, how would i adjust the voltage? 14.2-15.5. No warranty 95 civic air-ride RE-5 slam specialties 4-18's Dc xlm2's tuned 35hz 2-1100.1's @ .35 each 2-SD 250.2 nano amps 3-deka 9a31 1-deka 35ah 2-250 amp alts/ Adjustable regulator 159 sealed @ dash 51hz
Guest DC Power Rob Posted December 8, 2010 Report Posted December 8, 2010 Run a VCM... /Problem.. External adjustable regulators are good for one thing, burning up alternators, IMHO of course. Im sure many people would say different, but I don't care for them, especially the blue chinese made ones using 40 year old tech.. It's like a blind person throwing gas on a fire, they can't see just how bright it's getting so they keep on a pouring gas on until it's too late.. Theoretically, yes, but in practice it doesn't always work as you would think... You have to remember, the regulator has to react REALLY fast to control 2 alternators.. It will either be really jumpy with big voltage spikes, or really laggy trying to catch up with the 2 different alternators.. They wont split the load equally as well as you would think.. Not trying to discourage you from doing it, but 2 alternators with internal regulators will control and cooperate better than 2 alternators on a single regulator.. ok, but with 2 internal regulators, how would i adjust the voltage? 14.2-15.5.
