Coolwazabi Posted December 10, 2010 Report Share Posted December 10, 2010 trying to get dual exhaust.. is this the part i need ? http://shop.advanceautoparts.com/1/1/610940-y-pipe-by-walker-part-40591.html it says its an exact fit.. but i'm not sure if its dual to single from the engine.. or single from the engine and dual toward the back ? its a v8 and i only have 1 exhaust pipe so its meeting in the middle somewhere... Quote Link to comment Share on other sites More sharing options...
bassHZ Posted December 10, 2010 Report Share Posted December 10, 2010 (edited) i would say get something like this http://www.autozone.com/autozone/parts/Flowmaster-50-Delta-Muffler-Performance/2002-GMC-Yukon-XL-1500-2WD/_/N-jhggxZ9iz5p?counter=2&filterByKeyWord=muffler&fromString=search&itemIdentifier=372033_104800_0_&vehicleIdForService=117619098 the just run two pipes its easier but its mot going to be true dual exhaust what car is it ?? Edited December 10, 2010 by jl_audio Quote Link to comment Share on other sites More sharing options...
rusty959 Posted December 10, 2010 Report Share Posted December 10, 2010 If you have a v8 you have two exhaust pipes coming out of your engine. Looks like that is what would connect them together for a single pipe to the back, so it wouldn't be what you want. What kind of car is it for? Quote 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959 Link to comment Share on other sites More sharing options...
Coolwazabi Posted December 10, 2010 Author Report Share Posted December 10, 2010 1995 chevy caprice with a 4.3L v8... i know it'll have 2 sets of pipe from the engine.. but i'm wondering is this a replacement for that ? or does it connect to the single piece and make it into duals ? Quote Link to comment Share on other sites More sharing options...
ingramcaraudio Posted December 10, 2010 Report Share Posted December 10, 2010 1995 chevy caprice with a 4.3L v8... i know it'll have 2 sets of pipe from the engine.. but i'm wondering is this a replacement for that ? or does it connect to the single piece and make it into duals ? You should have two pipes from the manifold back that merge together at the catalytic converter and one out into the muffler. You can cut the converter out and run true duals with two new cats and two separate mufflers which will give you the best sound imo. And 4.3 is v6 5.0 or 5.7 in v8. Quote Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts Link to comment Share on other sites More sharing options...
bassHZ Posted December 10, 2010 Report Share Posted December 10, 2010 yeah are u sure its not an lt1 (5.7) like the police package ones ? Quote Link to comment Share on other sites More sharing options...
Coolwazabi Posted December 10, 2010 Author Report Share Posted December 10, 2010 yeah are u sure its not an lt1 (5.7) like the police package ones ? 100% sure.. Quote Link to comment Share on other sites More sharing options...
Coolwazabi Posted December 10, 2010 Author Report Share Posted December 10, 2010 You should have two pipes from the manifold back that merge together at the catalytic converter and one out into the muffler. You can cut the converter out and run true duals with two new cats and two separate mufflers which will give you the best sound imo. And 4.3 is v6 5.0 or 5.7 in v8. yeah broskeeee... straight from wikipedia L99 (4.3L) A 263 in3 (4.3 L) was based on a 305 in3 with updated block architecture to be Generation II and a reduced 3 inches (76 mm) stroke. It was designated the L99, and was introduced in 1994 for the Chevrolet Caprice. It was externally identical to the LT1, but the bore was 3.736 inches (94.9 mm) and the stroke to 3 inches (76 mm) giving it a displacement of 263 in3. The pistons used in the L99 were the same as the ones used in the Vortec 5000, but 5.94 inches (151 mm) connecting rods were used to compensate for the shorter stroke. Like the LT1, it features sequential fuel injection, reverse-flow cooling, and an optical ignition pickup. Output is 200 hp (150 kW) and 245 lb·ft (332 N·m). Due to its smaller displacement, it provides better fuel economy than the 5.7 L LT1, but at reduced horsepower & torque levels. its okay.. i've been wrong before.. Quote Link to comment Share on other sites More sharing options...
ingramcaraudio Posted December 10, 2010 Report Share Posted December 10, 2010 You should have two pipes from the manifold back that merge together at the catalytic converter and one out into the muffler. You can cut the converter out and run true duals with two new cats and two separate mufflers which will give you the best sound imo. And 4.3 is v6 5.0 or 5.7 in v8. yeah broskeeee... straight from wikipedia L99 (4.3L) A 263 in3 (4.3 L) was based on a 305 in3 with updated block architecture to be Generation II and a reduced 3 inches (76 mm) stroke. It was designated the L99, and was introduced in 1994 for the Chevrolet Caprice. It was externally identical to the LT1, but the bore was 3.736 inches (94.9 mm) and the stroke to 3 inches (76 mm) giving it a displacement of 263 in3. The pistons used in the L99 were the same as the ones used in the Vortec 5000, but 5.94 inches (151 mm) connecting rods were used to compensate for the shorter stroke. Like the LT1, it features sequential fuel injection, reverse-flow cooling, and an optical ignition pickup. Output is 200 hp (150 kW) and 245 lb·ft (332 N·m). Due to its smaller displacement, it provides better fuel economy than the 5.7 L LT1, but at reduced horsepower & torque levels. its okay.. i've been wrong before.. Lol damn sorry about that but the exhaust should be the same as i said but you could school me in that too. Quote Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts Link to comment Share on other sites More sharing options...
Coolwazabi Posted December 10, 2010 Author Report Share Posted December 10, 2010 yeah... kinda on a budget.. 2 new cats and 2 new mufflers with all custom piping.. uh that piece in that link is like $40 bux... hmmm Quote Link to comment Share on other sites More sharing options...
