rboudreaux77 Posted December 11, 2010 Report Posted December 11, 2010 What I mean is I am running 10 gauge wire to my sub and the hole in the push post is too small when I wire it parallel to fit 2 ends of 10 gauge wire in there. Right now I have one going in throught the front and one from the back but each is like half way and im scared it will fall out and fuck something up. My aq2200 has 2 pos and neg posts and I know its a 1ch amp so if I run one pos and neg from each to each pos and neg coil will that be the same as going from the amp to one coil and then jumping over like I have it now? If not what are some suggestions? Would 12 gauge wire be good enough for that much power? I hope I wrote that out like im trying to say lol Quote http://www.dcsoundlab.com/ 2008 Chevy Impala (Daily Driver) Pioneer touchscreen w/navi 1 DC XL 15" (around 4cuft ported box) 1 AQ2200 1 AQ90x4 Memphis MClass 6.5s (front doors) Memphis MClass 6x9s (rear deck) stock alt & front batt; 1 Red top in the trunk 139.2db sealed (on my old JL1000/1) 140.0db outlaw (on my old JL1000/1) 1992 Chevy S-10 Ext cab. (project car) Coming Soon: Bagged with some kind of wall.
OrionStang Posted December 11, 2010 Report Posted December 11, 2010 I wire outside the box. Easier to change ohm loads and only one wire per terminal Each bolt is connected to a terminal via 8ga. Quote SMD Super Seller My Feedback Thread
OrionStang Posted December 11, 2010 Report Posted December 11, 2010 How I did it for 3 subs. Quote SMD Super Seller My Feedback Thread
-Hobby- Posted December 11, 2010 Report Posted December 11, 2010 (edited) I installed these buss bars inside the box. Wired all the subs to them and then one lead from each to 2 pair of binding posts mounted to the face of the box. Edited December 11, 2010 by -Hobby- Quote
OrionStang Posted December 11, 2010 Report Posted December 11, 2010 I installed these buss bars inside the box. Wired all the subs to them and then one lead from each to 2 pair of binding posts mounted to the face of the box. I like that idea. Any pics of the buss bars installed on the box? Quote SMD Super Seller My Feedback Thread
rboudreaux77 Posted December 11, 2010 Author Report Posted December 11, 2010 Thats what ill do. I've seen that done on a few boxes and I was gonna do that for my next box. Right now I have the wires ran through the box and had it series so it wasn't a prob but with my new amp I wired it parallel and thats when I ran into the problem. Im not gonna be changing ohm loads once its hooked up so im not worried about that but ima do it that way anyway. It looks cleaner Quote http://www.dcsoundlab.com/ 2008 Chevy Impala (Daily Driver) Pioneer touchscreen w/navi 1 DC XL 15" (around 4cuft ported box) 1 AQ2200 1 AQ90x4 Memphis MClass 6.5s (front doors) Memphis MClass 6x9s (rear deck) stock alt & front batt; 1 Red top in the trunk 139.2db sealed (on my old JL1000/1) 140.0db outlaw (on my old JL1000/1) 1992 Chevy S-10 Ext cab. (project car) Coming Soon: Bagged with some kind of wall.
hdorre Posted December 11, 2010 Report Posted December 11, 2010 I like that idea. Any pics of the buss bars installed on the box? yeah, do you have any pics? Im interested Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
fritosaregood Posted December 11, 2010 Report Posted December 11, 2010 Im assuming its a dual 2 ohm sub. You can just wire each positive of the sub to each positive on the amp, and the same with the negatives, and it will be at 1 ohm Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
-Hobby- Posted December 11, 2010 Report Posted December 11, 2010 I like that idea. Any pics of the buss bars installed on the box? No picts of the inside. They are just bolted to some of my interior supports. I have 2 rows of 5 subs. With each sub wired in series and the pos and neg of each sub to a buss bar. All the neg terminals to one bar and all the pos terminals on the other bar. Then I have a 8g wire from each bar to a binding post on the box. Made it a lot easier to wire all the subs. If I did a bolt for each coil I would have 20 bolts on the front of the box Quote
OrionStang Posted December 11, 2010 Report Posted December 11, 2010 I like that idea. Any pics of the buss bars installed on the box? No picts of the inside. They are just bolted to some of my interior supports. I have 2 rows of 5 subs. With each sub wired in series and the pos and neg of each sub to a buss bar. All the neg terminals to one bar and all the pos terminals on the other bar. Then I have a 8g wire from each bar to a binding post on the box. Made it a lot easier to wire all the subs. If I did a bolt for each coil I would have 20 bolts on the front of the box I forgot how many subs you have. Makes sense now. Quote SMD Super Seller My Feedback Thread
