DC Sound Lab
Im assuming its a dual 2 ohm sub.
You can just wire each positive of the sub to each positive on the amp, and the same with the negatives, and it will be at 1 ohm
Yeah it is. And I figured I could do that just wanted to make sure
http://www.dcsoundlab.com/
2008 Chevy Impala (Daily Driver)
Pioneer touchscreen w/navi
1 DC XL 15" (around 4cuft ported box)
1 AQ2200
1 AQ90x4
Memphis MClass 6.5s (front doors)
Memphis MClass 6x9s (rear deck)
stock alt & front batt; 1 Red top in the trunk
139.2db sealed (on my old JL1000/1)
140.0db outlaw (on my old JL1000/1)
1992 Chevy S-10 Ext cab. (project car)
Coming Soon: Bagged with some kind of wall.
x2
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
4 ga butt connectors then directly to the amp. and where the subs are wired together i used a gold plated distro block
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 4589 Guests (See full list)
