Can I run my Amp at 2ohm on a 4ohm SUB?
If its dual 4 ohm, you shouldnt have any problem running it at 2 ohms just hook + to +, - to - on the sub, then run + from sub to + on amp and - on sub to - on amp
Edited by Gatorcity
comic on tv: I got a concussion from playing t-ball when i was younger, we dont really have time to go into that!
15 seconds pass
my girl: no one pitches to you in t-ball, do they???
Just wondering if I could run my amp a 2ohms on an Alpine Type R 4ohm version. Or am I better off with the 2ohm version?
Link to amp? If the sub is single 4 ohm, then it will only run on a 4 ohm load.
http://www.vminnovations.com/product_4486/Audiopipe_AP1800D_1800W_Mono_Power_Amplifier.html
750 Watt x 1 RMS @ 4 Ohms
1100 Watt x 1 RMS @ 2 Ohm
1800 Watt x 1 RMS @ 1 Ohm
Check out my first ever aftermarket purchase!
Should be ok, but I would be careful with setting gains, the type r's are only rated 500 watts rms I believe
15 seconds pass
Ahh dang I forgot to say Im going to be running two Type R's. So I'd say if I ran it at 2ohms, they should be getting just around the right RMS.
Edited by ChrisGLE
If youre running both at the same time, 2 dual 4 ohm subs cant be wired to 2 ohms, its either 1 ohm or 4 ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
Check out this link
15 seconds pass
  • Who's Online   1 Member, 0 Anonymous, 566 Guests (See full list)
