Ryman Posted December 12, 2010 Report Share Posted December 12, 2010 I just did my door panel... got me some vinyl and attempted to vinyl it once but failed miserably... There has to be a way to do this door panel i don't think it's that hard for experienced guys any tips or tricks on how to wrap vinyl would be great... and also I don't have a picture of the current door panels there is a picture frame like frame i made to go around the mounted crossovers so i need to vinyl that as well let me know if you need a current pic i'll snap one later do i need a heat gun? what does it do? where do i start laying down the vinyl? what kind of adhesive should I use? tips? Link to comment Share on other sites More sharing options...
alphasig293 Posted December 12, 2010 Report Share Posted December 12, 2010 Check with ndmstang65, think he just finished wrappin mine n vinyl, maybe he can give u some tips 2005 Lariat F-150 On 30 inch DUBS 6 Crossfire XS-V2 18's 2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4 12 - 6.5 Crescendo mids and 4 Crescendo supertweets SMD 340 alt, Mechman 270 alt 7 NSB 170 batterys Link to comment Share on other sites More sharing options...
jmitch Posted December 12, 2010 Report Share Posted December 12, 2010 I just did my door panel... got me some vinyl and attempted to vinyl it once but failed miserably... There has to be a way to do this door panel i don't think it's that hard for experienced guys any tips or tricks on how to wrap vinyl would be great... and also I don't have a picture of the current door panels there is a picture frame like frame i made to go around the mounted crossovers so i need to vinyl that as well let me know if you need a current pic i'll snap one later do i need a heat gun? yes what does it do? helps the vinyl stretch makes it easier to work with where do i start laying down the vinyl?i usually start close to where the pod are what kind of adhesive should I use?u can use the splay kind or rubber cement tips?work it slow and make sure its tight and smooth I know a lil about everything so dont call me Mr. Know it All. Link to comment Share on other sites More sharing options...
