timothya Posted December 17, 2010 Report Posted December 17, 2010 Hi, I was wondering if you knew how to wire up the ignition harness for a Viper 5301 on a 2001 Corolla S. Heavy Gauge H3/1 (Pink) - (+)Ignition 1 Input/Output --- H3/2 (Red/White) - (+)Fused Ign2/Flex Relay Input --- H3/3 (Orange) - Accessory Output --- H3/4 (Violet) - Starter Output --- H3/5 (Red) - (+)Fused Ignition 1 Input --- H3/6 (Pink/White) - Ignition 2/Flex Relay Output --- H3/7 (Pink/Black) - Flex Relay Input 87a key side --- H3/8 (Red/Black) - (+)Fused Accessory/Starter Input--- Thank you for any help. Quote
Shyne151 Posted December 19, 2010 Report Posted December 19, 2010 Here is everything you should need: 2001 Toyota Corolla DirectWire 2.0 Vehicle Information Remote Start Item Wire Color Polarity Wire Location 12 Volts white (50A) + ignition switch, white 8 pin plug, pin 2 Second 12 Volts black/red (15A) + ignition switch, white 8 pin plug, pin 7 Starter red + ignition switch, white 8 pin plug, pin 8 Second Starter N/A Ignition black/white + ignition switch, white 8 pin plug, pin 6 Second Ignition black/yellow + ignition switch, white 8 pin plug, pin 4 Third Ignition N/A Accessory blue/red + ignition switch, white 8 pin plug, pin 3 Second Accessory N/A Third Accessory N/A Keysense Data Bus Can Bus High Can Bus Low Can Bus Sw Power Lock use factory alarm arm Power Unlock use factory alarm disarm Lock Motor blue 5 wire dash fuse box, right side, white 14 pin plug, pin 7 Driver Unlock Motor red 5 wire dash fuse box, right side, white 14 pin plug, pin 12 Parking Lights (-) lt. green/black - headlight switch, white 17 pin plug, pin 14 Parking Lights (+) green + dash fuse box, white 10 pin plug, pin 9 Hazards same as turn signals Turn Signal (Left) green/black + turn signal switch, white 17 pin plug, pin 1 Turn Signal (Right) green/yellow + turn signal switch, white 17 pin plug, pin 3 Headlight red/white - headlight switch, white 17 pin plug, pin 13 AutoLights N/A Reverse Light red/black + driver kick, harness to rear Left Front Door Trigger red/white - behind dash fuse box, white 3 pin plug, pin 1 There are at least 5 red/white wires at the dash fuse box. Some will only pick up individual doors. Meter them to find the one that will get all the doors. It will be the one that goes up to the instrument cluster. It is in a 12 pin plug on the back of the dash fuse box. For domelight supervision use one of the individual door triggers. Right Front Door Trigger Left Rear Door Trigger Right Rear Door Trigger Dome Supervision see left front door trigger Trunk/Hatch Pin red/white - luggage compartment light, gray 2 pin plug, pin 2 On vehicles with the factory alarm, can also find this wire at the alarm module above the driver kick. Rear Glass Pin Hood Pin red - hood switch On vehicles with the factory alarm, can also find this wire at the alarm module above the driver kick. Trunk/Hatch Release Trunk Release Motor Fuel Door Release Power Sliding Door (Left) Power Sliding Door (Right) Factory Alarm Arm blue/black (passenger door key cylinder) - dash fuse box, right side, white 14 pin plug, pin 3 Factory Alarm Disarm green/white (passenger door key cylinder) - dash fuse box, right side, white 14 pin plug, pin 6 Disarm No Unlock Trunk Alarm Shunt Tachometer red/blue, yellow/green, gray, or white ac any ignition coil, black 4 pin plug, pin 3 Wait to Start Neutral Safety Clutch Pedal Fuel Pump Rear Defroster black/blue - latched rear window defogger switch, white 8 pin plug, pin 2 Mirror Defroster N/A Left Front Heated Seat Right Front Heated Seat Speed Sense purple/white 4-Pulse center console, 22 pin plug Brake Wire green/white + brake switch, blue 5 pin plug, pin 1 Quote -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
