AcIdBuRn02ZTS Posted December 18, 2010 Report Share Posted December 18, 2010 Hey guys... here is a quick question... I'm running a 14^3ft. net enclosure with a double baffle (49"w x 34"d). The walls of the enclosure are braced using 1/2" all thread however I wanted to know if I needed to run a 2x4 from front to back to support the center of the double baffle or is it even needed since I'm using the double? I'll be running 2 re audio sx18s on around 1.5-2k rms per driver eventually, however 1krms per for the time being. Anyways... this is holding up progress at the moment so if someone could chime in, I would greatly appreciate it. Thanks -Chris 03' Black Z71 Tahoe 3" Lift / 315/70/R17 Goodyear Duratracs Eclipse AVN6620 Touchscreen Head Unit Hifonics BRX3016 - 3krms @ 1ohm 2 RE Auido SX 18s - 14.5^3ft net @ 30hz w/ 200^2in. port120hp Cummins 4bta Swap Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted December 18, 2010 Report Share Posted December 18, 2010 Hey guys... here is a quick question... I'm running a 14^3ft. net enclosure with a double baffle (49"w x 34"d). The walls of the enclosure are braced using 1/2" all thread however I wanted to know if I needed to run a 2x4 from front to back to support the center of the double baffle or is it even needed since I'm using the double? I'll be running 2 re audio sx18s on around 1.5-2k rms per driver eventually, however 1krms per for the time being. Anyways... this is holding up progress at the moment so if someone could chime in, I would greatly appreciate it. Thanks -Chris i would brace it. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
iceman1575 Posted December 18, 2010 Report Share Posted December 18, 2010 Hey guys... here is a quick question... I'm running a 14^3ft. net enclosure with a double baffle (49"w x 34"d). The walls of the enclosure are braced using 1/2" all thread however I wanted to know if I needed to run a 2x4 from front to back to support the center of the double baffle or is it even needed since I'm using the double? I'll be running 2 re audio sx18s on around 1.5-2k rms per driver eventually, however 1krms per for the time being. Anyways... this is holding up progress at the moment so if someone could chime in, I would greatly appreciate it. Thanks -Chris i would brace it. Of course you would. You like it stiff and sturdy. POTATO! Link to comment Share on other sites More sharing options...
fritosaregood Posted December 18, 2010 Report Share Posted December 18, 2010 I would add it too, thats a big baffle to just count on doubling it to hold it. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
