Rell Posted February 1, 2011 Author Report Share Posted February 1, 2011 Been playing around with some measurements for the 10in rings, set the depth to just take off a little wood for a visual. I think I will run with it. Few weeks ago I got one of the back doors hung up. Aligned everything and got the holes drilled for the key slots for the door panel clips Gotta beef those slots up a bit with some chop mat, then they will be good to go. Still have to do the other 3 doors. Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 1, 2011 Report Share Posted February 1, 2011 moar! this is coming out really sick, i love it Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
El1T3Bass Posted February 1, 2011 Report Share Posted February 1, 2011 damn this is amazing work man, keep it up! wanna do mine wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic Link to comment Share on other sites More sharing options...
Rell Posted February 1, 2011 Author Report Share Posted February 1, 2011 Gotta go buy new bit tonight, finish up the rings tomorrow. Then try and get all the doors up on the car hopefully, to get the key slots made. After that its time for some glassing. And move onto the arm rest. Link to comment Share on other sites More sharing options...
ch0sen Posted February 2, 2011 Report Share Posted February 2, 2011 i've had to use those diablo bits for work before, man, they don't hold up to a bosch bit, try ordering your next bits online, theyll do much better, but diablo do much better on mdf than they do on plywood My current 95 Jetta Build w/ pioneer h/u 2 RD Sonance 10's with flatwind coils 2 Audiopipe apsm 1500.1s 1 Hifonics Brutus Elite 60x4 1 XS d925 1 Stinger spv35 1 1000 amp lead acid 50 ft of 0/1 ofc from Audiotechnix all powerbass components, and coaxils, 4 sets buildlog = http://www.stevemead...2-rd-10s-build/ My build for my wife. http://www.stevemead...01-f-150-build/ Link to comment Share on other sites More sharing options...
Rell Posted February 2, 2011 Author Report Share Posted February 2, 2011 Funny cause the bit I used today for cutting the rings is a bosch bit. This is the second one I broke. And yes to those thinking, I do go at a nice steady pace, in the correct cutting direction and I make multiple passes so I make sure I don't over work the bit. I will be making a order on some quality bits soon, maybe when there is a nice sale on one of these sites. Link to comment Share on other sites More sharing options...
Rell Posted February 22, 2011 Author Report Share Posted February 22, 2011 Just to update, some of my main priorities have been on how I will construct my arm rests, and what kinda window switches/door locks etc I will run with. Currently my car has the typical 70's 80's etc type of style window/door lock switches like these. Which I don't really think will fit the over all look of the doors when done. These are the door pulls I will be using Lokar IDP-2003 Lokar Billet Arm Rest Door Pulls And these are the door handles I'm hoping to have success installing. Lokar IDH-2001 Lokar Oval Billet Interior Door Handles Other wise it looks like I might have to either scrap this build or install door popers and eliminate the door handles altogether(which I do not want to do) Anyone here have any experience installing these kind of door handles before? I'm looking into using some kind of Billet made/polished chrome looking window and door lock switches to run with so they match with the Lokar door pulls and door handles. Been looking at these. YearOne Online Shopping However I don't like how the Driver door(4 switch panel) looks like this. Horizontal bezel for the switches. I would like it to be a vertical bezel to place the switches in. So if I go with those I will have to do some research and see who has a cnc machine to produce me a nice looking bezel for the switches. Or if the company that sells the kit can do it. Doubt it though. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - I have an idea where I will mount a bracket onto the doors. Most likely hidden under the arm rest where I can add a couple bolts to aid in helping to support all the weight. That way its not just all up to the door panel clips. There is also a slight issue with mounting the door panels onto the doors. And I don't even want to imagine how annoying it would be to try and get them mounted once I get to glassing and speakers are in. Since the top metal piece of the door panel hooks over and onto the doors its a little harder to get them on with the extended door panel clips that I thought would be better. So I'm thinking about splitting the doors here at the red line. I would first mount on the bottom half of the doors then the top. And have them join together somehow and look as clean as possible. Something like this. Dark and light grey parts is the 1/2in trim piece I made to go around the doors. Link to comment Share on other sites More sharing options...
SoCaLBaMF Posted February 22, 2011 Report Share Posted February 22, 2011 Holyyy attention to detail! Can I haz your skills??? 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500 Link to comment Share on other sites More sharing options...
Rell Posted February 23, 2011 Author Report Share Posted February 23, 2011 Mailman dropping off stuff little by little, some Lokar billet polished door pulls came in today. I like these Link to comment Share on other sites More sharing options...
Spitfire2k6 Posted February 23, 2011 Report Share Posted February 23, 2011 Damn thats some nice work, cant wait to see it finished! Live life to the full... Then TURN THAT BITCH UP! Link to comment Share on other sites More sharing options...
