this is my first install ever so yeah
so i opened up my dash to switch out my head units and theirs ALOT of unexpected wires
heres what i have
http://www.amazon.com/gp/product/images/B003LUTVBK/ref=dp_otherviews_3?ie=UTF8&s=electronics&img=3
(just the pics) i took my own but they came out shitty
and heres what i found (in my car)
wtf theirs alot of wires that i don't have space for so do i just not use them and if so which ones do i use
its a 2007 scion tC
the headunit in there now is a pioneer t1806
and the one im putting in there is a pioneer 8000
thanks for any help you can give
go find an Eclipse AVN6620...you won't need to change anything, it'll just plug right in. On that note, the wiring is the same as a toyota, so use a toyota harness adapter.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
buy the right harness and kit if needed from stereo shop. you wont use all the plugs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   1 Member, 0 Anonymous, 1457 Guests (See full list)
