94 explorer 2 RE Audio MX 18
how much port area is that?
and hope you brace your roof before you put the subs in or you best get usto listening to slapping metal
also how wide is your box and how tall?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Right on man Keep those pic comming
is be posting pics of thursday. today i have alot of sanding to do and ill be putting some carpet on the box and hooking everything up
the port is 11x11 and the box is 41w and 15h
so 41 x 15 x roughly 35?
R.I.P!
(Nov-29-2009)
92 explorer
current build
whats up im the guy who designed the box and am helping him build it! the box is 9.5 cu. ft after all displacement the box is 41wx15hx38d and is double baffled and supported with 1 1/4" dowel rod box is designed for the aq 3500 since there was no reason to build a bigger box for the smaller amp when he is upgrading soon. as for the roof i told him he will need at least 2 layers of some kind of sound dampener and if we can support it some other way we will try but this is just the start of it!
2011 usaci streetbeat 2 world champion
2012 usaci streetbeat 2 world champion
2012 iasca advnw1 and lightweight bassboxing 2nd place
2013 usaci mod 1001-2k world champion
2013 meca mod 5 2nd place
2014 mwspl adv 2 world champion
2014 meca mod 4 world champion
usaci streetbeat 2 world record holder b and k mic
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
first 160 mwspl adv 2 8k clamped class
ah sounds good reason i asked was because your loosing alot of air space on the sides
if you were to build the box up on the sides over wheel wells you can gain alot of cubic foot and go to a port firing into the rear (loudest in exploder i've found)
something along the lines of this
as for roof yeah get on that before it does some damage
other then that build looks good- keep up ze good work :clapping:
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks yeah i thought about that but it was his first box so wanted to keep it simple. also hopin to fit a battery/ amp rack about the wheel wells ive never really built a explorer but just tryin to see what we can do and i heard the roofs are like a tin can and if you dont deaden them it will rip or break supports so thats prolly next on the list but he needs batteries first! takes power to make power! i think it will be a nice build when we are all done i jsut wanna see what 2 18's below the window line will do in a explorer!
also all this was done with a circular saw and jigsaw my router wasnt workin and my table saw is still at my old house so it isnt the prettiest on the edges but thats what sanding and carpet are for!Lol
no excuses for not using a table saw and router haha as long as you have a straight edge and take your time your good
as for roof your right haha tin can and broken supports are very common
and if you need any help with explorers send me a pm i'll help to what i can
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks i just might ive done some research to get a start but i know its just test and tune so once we get all the electrical and support work done then we will see what it will do we did the big 3 and gonna put the biggest batt we can up front just gotta go measure the space and see what we can fit!
