RobClay Posted December 29, 2010 Report Share Posted December 29, 2010 Needed some price quotes on 200-270 amp alts. 2002 Ford Explorer Sport 4.0L SOHC Stock 130 amp alt. Also interested in seeing if the voltage booster would work with mine, thanks in advance. Quote 2 SSA Xcon 18's Sundown 2500D Pioneer 4 Stinger SPV35 batts SecondSkin Audio Damp Pro Knukonceptz Flex[/size][/b] Link to comment Share on other sites More sharing options...
MECHMAN Posted December 29, 2010 Report Share Posted December 29, 2010 Needed some price quotes on 200-270 amp alts. 2002 Ford Explorer Sport 4.0L SOHC Stock 130 amp alt. Also interested in seeing if the voltage booster would work with mine, thanks in advance. The AVBM is not compatible with your stock alternator. We use a special regulator in our alternators for your truck, so that they are compatible with the AVBM. 220 amp (135 at idle) direct bolt in, comes with HD custom rectifier, overdrive pulley, = $399 270 amp (165 at idle) Direct bolt in, comes with HD custom rectifier, overdrive pulley, comes standard with the AVBM module, based on our hybrid late model custom housing = $499 The 270 is actually a better value in this particular application, because it comes standard with the AVBM. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
