is the amp getting hot. what sized power wire are you using. what is your voltage dropping to. does the protect light come on. is your ground bolted to a thick piece of metal that has the paint sanded off.
i just had the same problem and went through everything it started pissing me off come to find out i had a pinch in the remote wire to the amp and when i turned it up the vibration would shake it but the amp stayed on so check your remote first just run a new temporary one to check it
TEAM PULSE CAR AUDIO
MECA 150.3
SEALED ON DASH 151.5
FLOOR 152.2
we ran a new remote wire and put in a relay to run my sub and highs amp and it solved my problem. i said it wrong when i turn the subs up to far my highs would cut out but subs would stay on my voltage at the remote wire to the highs amp was dropping to 8 or 9 volts cutting my highs out
MECA 150.3
FLOOR 152.2
