blackrosetiger Posted January 1, 2011 Report Posted January 1, 2011 I got a pretty good deal on a Power Acoustik 5500D from a buddy of mine for $150. Now before everyone and their grandma jumps on me for wanting a PA let me say this: All I want it for is to break in my subs. My question is how well will this amp serve this purpose? I plan on starting them off with about 500 watts RMS. I'll be running 6 Almani S7 10s between 30 & 35Hz (Havent made up my mind yet) Specs: Power Acoustik 5500D Almani S7 10" Performance Specs. Fo 31 Hz. Vas 24 L Qes 0.63 Qts 0.55 XMax 15 mm ( just under 5/8 of an inch ) Sd 0.0363 m2 SPL 86 dB/m/1V Wattage 2000 Watts (1000 watts RMS) Surround Overmolded TPR Rubber Cone Stiff Non Pressed rear Cone and Kevlar for the Front Cone Nomex Spider Heavy Duty Dual 3" 4 ohm Voice Coil with External Venting Precision Computer Optimized Magnet Die Cast Machined Frame with Peripheral Venting 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
byers319 Posted January 2, 2011 Report Posted January 2, 2011 you got a amp just to break in your subs
blackrosetiger Posted January 2, 2011 Author Report Posted January 2, 2011 Sure why not I was helping out a friend 1st of all. And I could always use another as insurance if my crescendos fail. (just realized I need to update my sig) 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
Guest Posted January 2, 2011 Report Posted January 2, 2011 How to break in your subs: play them full power. That pa can only output about 1800 rms. Fyi
dugee81 Posted January 2, 2011 Report Posted January 2, 2011 You only really need to break in subwoofers like DD's I believe. Most subs are plug n play. I tuned my amp to full power and started poundin on my HCCA right when I got it 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
