so to i baught a Interfire IB2900C amp from my friend for $40 did i get an amazing deal? or is it not that great.
and if someone could put a link of where i can see this amps specs, thatd help me alot cuz if its on their site i didnt look hard enough... but i couldnt find it and ive tried google and only found the max watts of it
its an old amp back from 2004
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
What amp fuse does it use, can tell you about what you could expect from it
¿ǝɯɐƃ ǝɥʇ
2 30a fuses
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
If its a Class D amp you are probably looking at 500-600rms
¿ǝɯɐƃ ǝɥʇ
damn thats alot more then i thought i was gonna get for $40 haha
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
It seems after some research that its a 2 channel and does 250rms a channel at 2 ohms, and 500rms bridged at 4ohms
Edit: About* some sites say 225rmsx2 others say 250rmsx2 either way you wouldnt notice a difference
¿ǝɯɐƃ ǝɥʇ
Good deal. I had an Interfire 4 channel at one time. I was pleased with it till it took a shit on me. Worked for a few years though.
1991 Lincoln Town Car Signature Series
DC Power 270 Amp Alt
Big 3
Kicker/KnuKonceptz 0 Gauge Power wire
XS Power D6500
XS Power D3100
Pioneer Headunit
JBL Mids and Highs
Rockford Fosgate 400.4
3 Sundown Audio SA-10's wired @ .67 ohms
American Bass 150.1
I had a pair of these a while ago, still have 1 in my garage hanging on a wall.
They are a bit cheaper, but do ok.
550watts rms @ 4ohms bridged
350watts rms by 2 @ 2ohms stereo
225watts rms by 2 @ 4ohms stereo
1100 watts PEAK
Not recommended for bridged 2 ohms, but after a while you will blow it @ 2 ohms bridged.
Tried burping the amps at 1 ohm bridged just for fun and after the 2nd burp amps blew.
They are pretty cheap amps, nothing spectacular at all, but should do fine if you run it at their rated impedance's.
Heres a pic of the amps guts
Just found this in my photobucket too.
From their site
well since uve had some of these amps before, i have a question for u.
wat does it mean between mono and stereo on the rms rating?
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
The same as it means with any 2 channel amp when you bridge the channels.
You take the left channel Positive wire and hook it up to your subwoofers positive speaker wire.
You take the right channel Negative wire to hook it up to your subwoofers negative speaker wire.
so mono would be when your bridge the amp, and it is no longer has a left and a right output like stereo does.
The amp will do more power wired at 2 ohm stereo then it will bridged at 4 ohm.
  • Who's Online   0 Members, 0 Anonymous, 480 Guests (See full list)
