xxlbigboono Posted January 4, 2011 Report Posted January 4, 2011 I have a 2000watt amp and 2 15's well i hooked the 2 15's up and they were beatin hard but then i get arrogent and decide to hookup my 2 10's aswell and it all worked for about 10 seconds and then it just quit, The power wire is like 14 gauge i can put it against metal and no spark with the car on does that mean my power wire is fucked or whats up lol please help
Alex K Posted January 4, 2011 Report Posted January 4, 2011 14gauge on 2k lol. sounds like a blown fuse 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
xxlbigboono Posted January 4, 2011 Author Report Posted January 4, 2011 14gauge on 2k lol. sounds like a blown fuse Would you happen to know where and what number the fuse is
scfaust Posted January 4, 2011 Report Posted January 4, 2011 when u hooked up the tens u may of droped ur ohm load to low. do u know what ur amps is and the ohm load on ur subs but i hope u just blew a fuse if so ur lucky u need to be carefull with that stuff. but if it dont spark it may be a fuse or umelted ur wire some where http://i720.photobucket.com/albums/ww203/scfaust1/alphadamp.png
xxlbigboono Posted January 4, 2011 Author Report Posted January 4, 2011 when u hooked up the tens u may of droped ur ohm load to low. do u know what ur amps is and the ohm load on ur subs but i hope u just blew a fuse if so ur lucky u need to be carefull with that stuff. but if it dont spark it may be a fuse or umelted ur wire some where I doubt its an ohm problem lol there 2 shitty ass tens that are generic, it played fine on 1 10 and 2 15's basicly within 10 seconds of the second ten boom it all quit working
Guest Posted January 4, 2011 Report Posted January 4, 2011 why would you want to hook up 2 different sized woofers together anyway? and yeah you more than likely dropped the ohm load too low and kicked the amp into protection or even worse, fried the amp. what kind of 2000 watt amp is it? model number would help out greatly. and you can check the fuse yourself. most amplifiers have fuses near/next to the power wire input. pull it out (if its there) and look at it through the little looking panel. if the little wire in there is intact, then its fine. if its not intact, replace it and dont hook up those 2 10's and 2 15's together ever again.
Guest Posted January 4, 2011 Report Posted January 4, 2011 when u hooked up the tens u may of droped ur ohm load to low. do u know what ur amps is and the ohm load on ur subs but i hope u just blew a fuse if so ur lucky u need to be carefull with that stuff. but if it dont spark it may be a fuse or umelted ur wire some where I doubt its an ohm problem lol there 2 shitty ass tens that are generic, it played fine on 1 10 and 2 15's basicly within 10 seconds of the second ten boom it all quit working you doubt its an ohm load problem? you're the one who hooked up 2 15's and 2 10's together and you're coming to us asking for help. grab a DMM and test the resistances of the way you had it hooked up to the amp. its probably gonna show like .25 or .5 ohms.
xxlbigboono Posted January 4, 2011 Author Report Posted January 4, 2011 why would you want to hook up 2 different sized woofers together anyway? and yeah you more than likely dropped the ohm load too low and kicked the amp into protection or even worse, fried the amp. what kind of 2000 watt amp is it? model number would help out greatly. and you can check the fuse yourself. most amplifiers have fuses near/next to the power wire input. pull it out (if its there) and look at it through the little looking panel. if the little wire in there is intact, then its fine. if its not intact, replace it and dont hook up those 2 10's and 2 15's together ever again. quantinum audio 2000 watt amp i bought it off ebay and didnt say model number ect. lol its just weird the dude i bought the van from doesnt even have the power wire ran to battery its mixed with some other wires lol, I have a 0 gauge wire just no tools to install to battery terminal, With the car on i can take the power wire and hold it against pure steel and nothing sparks lol
xxlbigboono Posted January 4, 2011 Author Report Posted January 4, 2011 when u hooked up the tens u may of droped ur ohm load to low. do u know what ur amps is and the ohm load on ur subs but i hope u just blew a fuse if so ur lucky u need to be carefull with that stuff. but if it dont spark it may be a fuse or umelted ur wire some where I doubt its an ohm problem lol there 2 shitty ass tens that are generic, it played fine on 1 10 and 2 15's basicly within 10 seconds of the second ten boom it all quit working you doubt its an ohm load problem? you're the one who hooked up 2 15's and 2 10's together and you're coming to us asking for help. grab a DMM and test the resistances of the way you had it hooked up to the amp. its probably gonna show like .25 or .5 ohms. True sorry, I dont have a DMM but if its too low how can i fix it haha sorry im a noob at this just trying to learn :/
Guest Posted January 4, 2011 Report Posted January 4, 2011 quantinum audio 2000 watt amp i bought it off ebay and didnt say model number ect. lol its just weird the dude i bought the van from doesnt even have the power wire ran to battery its mixed with some other wires lol, I have a 0 gauge wire just no tools to install to battery terminal, With the car on i can take the power wire and hold it against pure steel and nothing sparks lol umm unless you want your car to catch on fire, dont touch a power wire to bare metal. and that amp, with a quick search, only has short protection. True sorry, I dont have a DMM but if its too low how can i fix it haha sorry im a noob at this just trying to learn :/ how can you fix it? for one, dont wire 2 different subwoofer sizes together ever again. two, make sure the ohm load will be compatible with your amp. three, make sure your subwoofers have the same voice coils. as in, if you have two subwoofers, make sure they are both dual 4 ohm or dual 2 ohm or whatever. not one is dual 4 ohm and the other is dual 2 ohm, that wont work.
