I'd put that fuse that came with the amp within 12" of the amp to protect the amp, and also fuse within 12" of the battery to protect the wire and your vehicle
Uhh, how is fusing within 12" of the amp going to protect the amp any more than the fuse at the front? He's only running 1 battery. Resistance of the wire from the front of the vehicle to the back is negligible, may as well have 2 fuses side by side at the battery.
Who here actually knows how a fuse works and why we use them?
The fuses on your amp, 99% of the time, don't do sh!t. The one thing they have going for them is they'll save your amp if you hook it up backwards. Otherwise the fuse rating is plenty to allow your amp to completely shit itself and pour awful smelling smoke and the fuses won't even get hot. If you've fused the power feed to it with a lower-rated fuse than the fuses on your amp itself you may as well pull them out and solder the pads together inside, for as much good as they're going to do you.
10.x volts fo' life!
