Fi Car Audio
im getting a fi ssd 12.
the extra options like the bp power and the flat wind coil i sorta of understand from the explanation on the website but i want to know what i should get and not get to achieve the best outcome for a daily used sub.
only question is, how much power will you throw to it?
im getting a amp that can put out 1500 rms at 1 ohm and 900 at 2ohm and most likely will do it at 2 ohms.
but from what i read it says that bp power can increase how much it can handle. is that true?
Yes it will increase thermal power handling.
With this sub mechanical power handling if where you run into trouble. Its just not designed for a ton more than rating.
I would just get a dual 1 and wire in series. It will be a almost perfect match.
Edited by Ford302Redneck
  • Who's Online   0 Members, 0 Anonymous, 2309 Guests (See full list)
