Okay thanks.. Well the problem was weird cause since I installed new components in the front the cap turns of like every 3 minutes by itself so I was like fuck it, I see people using battery's for a reason right..And The bass is not hitting as much as it usually does.. Like latterly no bass Thanks for the info.
So I am guessing an sx battery?? Like how Manu watts should it be?
Edited by Jesus805
dude.. buy more wire and do the big three before you buy another battery... if you add a battery without upgrading your electrical your just adding to your problem
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
you shouldnt really need it for that..
do the big three upgrade and get some good wire unless you have it already..
also upgrade your grounds.
sierra as in truck? if so ground your up front battery to the frame and then ground your amp to the frame as well your gonna have to drill a hole though..
Yeah it's a gmc Sierra.. So a direct line the frame? Why not just to the body?
Edited by Jesus805
So just change my 4 gauge wire to 0 gauge.... And then the big 3?
because the body is a horrible ground.. your body is spot welded together a thousand times and your curent is trying to travel through those which is highly resistive (is that a word? anyways upgrade your big three. and ground the body or better yet ground the alt mount to the frame up front.. and then ground your amp to the frame.. your voltage issue will be GONE .. because grounding to a nice thick peice of steel is better than on a thin peice connected by tiny little spot welds..
you really shouldnt need a battery for that amp. if your getting voltage drop somethings wrong.. aka not having a big three done.
trust me and save yourself some money.. go to knukonceptz and get yourself some wire for the big three. what wire do you have for your power wire now? is it some cheap install kit? if so order some new power wire. and enough wire to do the big three and the frame ground.. youll be happy you did.
if your amp doesnt accept 0 guage then theres no need for it..
go on knu and get the OFC WIRE get the size you need and call it a day.
Edited by chewie
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
Got it man thanks! Let's just hope that's the problem. But does it matter that I am also running a 2 channel amp for my mids and highs. "arc Audio 300.2" .. And new focal polyglass components
The brand is scoche for the wires I am using, seem perry thick
editied a few times.. might wanna re read ^^^
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
no youll be fine after the upgrade.. do all your grounding to the frame.. your mids and highs amp would be fine off the schosche wire but i would upgrade your amp wire..
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
  • Who's Online   0 Members, 0 Anonymous, 3082 Guests (See full list)
