osamio Posted January 8, 2011 Report Posted January 8, 2011 This is hard to explain, but here goes.. I just installed an equalizer/preamp... I used high level inputs on it, and RCA output to my soundstream amp... I attached a DMM to the amp, set the gains, played a few test tones, seemed good to go, Then i go to connect the subs to the amp, and as soon as i touched the second speaker wire, the subs SLAMMED at there was a large spark at the terminal.. i pulled the wire away like instantly, took out the DMM and touched it to the amp output, there was NOTHING. it seemed fine, i pulled out the RCA going into the amp, and tried attaching the subs again, and it was fine, no spark, no output from the subs. So, i figure there is some signal coming from the equalizer, but why not when the DMM was connected? only the when the subs were connected did this signal or whatever u want to call it come through the amp... I hope i explained this well enough for someone to maybe guess what's wrong? Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Freshman6969 Posted January 8, 2011 Report Posted January 8, 2011 might have grounded out something? are your rcas ran along the power wire? Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
osamio Posted January 8, 2011 Author Report Posted January 8, 2011 might have grounded out something? are your rcas ran along the power wire? They run close to eachother at the very end of the run, but i don't see anywhere it could be shorting out... and why wouldn't the same thing happen when the DMM was on the amp? it was only when i tried to hook up the subs, so i figured maybe the speaker wire was shorting to power or ground somehow but i didn't see anything... Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Guest Posted January 8, 2011 Report Posted January 8, 2011 power light on? protect light on? fuses good? Quote
osamio Posted January 8, 2011 Author Report Posted January 8, 2011 power light on? protect light on? fuses good? Fuses are good, I honestly can't check if it protects, the only way to make it happen is by connecting the subs, but i don't want to do it because i can tell it's WELL over their rating... if i leave it on long enough to check i'm gonna blow the subs or the amp or both. Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Guest Posted January 8, 2011 Report Posted January 8, 2011 are the subs shorting out somewhere? could be a loose speaker wire or even a single strand touching the opposite polarity. Quote
bumonskateboard6 Posted January 8, 2011 Report Posted January 8, 2011 Don't hook up subs with the car on.... Check your subs if you feel the power is way over their limit. Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
osamio Posted January 8, 2011 Author Report Posted January 8, 2011 are the subs shorting out somewhere? could be a loose speaker wire or even a single strand touching the opposite polarity. I'll have to go check, I did check the impedance and it read fine, there was no short at the terminals, does that mean i need to check at the terminals on the subs? or should reading a normal impedance indicate that there are no shorts? Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Guest Posted January 8, 2011 Report Posted January 8, 2011 are the subs shorting out somewhere? could be a loose speaker wire or even a single strand touching the opposite polarity. I'll have to go check, I did check the impedance and it read fine, there was no short at the terminals, does that mean i need to check at the terminals on the subs? or should reading a normal impedance indicate that there are no shorts? just to be totally safe, hook up ONE subwoofer (one coil at a time also if possible) to the amp at a time and see if that happens again. did you also try different rca cables since you said it doesnt happen if the rca's are unplugged? Quote
osamio Posted January 8, 2011 Author Report Posted January 8, 2011 Don't hook up subs with the car on.... Check your subs if you feel the power is way over their limit. Would it matter if the car was on? if you are saying i should hook the subs up with the car off then turn it on, i'm pretty sure i'll see the same result... the amp was on, but there was definetly no music playing. and what do u mean check the subs? they didn't blow, but they will if i continue to do it. Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
