Found something about the big 3....Opinions
i was reading something about the big 3 because i did teh big 2 ground to neg pos to alt pos and i was looking for how to do chassis to ground on a 2008 mustang. idk why im just confused on where to bolt it on the engine. i saw a guy say just go from an alt bracket bolt to negative on battery? and i was curious if this would work or if that guy is completely out of his mind.
this is the link if it helps any. My link
thanks
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
alright cause thatd be easy since my alt is like 3 feet away from my battery
anymore opinions?
Wire: Knu 0 gauge
as long as the bolt goes into the block it will work
well from what i understand ffrom reading that if its correct is that the casing of the alt is the ground. soo its connected to the engine there fore all the engine to chassis is really for the alt ground? idk if that makes sense or if its correct at all
Wire: Knu 0 gauge
Big 3 is
1. Alternator + to batter +
2. Alternator casing or engine block to battery ground - the closer to the alternator the better, if you can do it right to the alternator casing then do it, less resistance then going through the engine. but may only be by a little bit
3. Battery Neg to chassis, go to a main part of the car, like a strut tower, or a frame rail, do not go to some crappy piece of welded metal
Some people will do alternator casing to chassis, but isn't necessary as the wire runs from the alternator casing to battery neg to chassis
Tip: keep wires away from extreme heat, also some people fuse the alternator to battery, but you have to be careful, if anything use a circuit breaker that is designed for the wiring or slightly above what the alternator peaks at. The main issue is if fuse blows or the circuit breaks then you loose all main power, and you will destroy your battery running it into such a low charge if its not fixed right away, that's why a voltage meter that's on all the time is helpful. Another reason for fusing is so you don't burn out the diodes in the alt, as stock ones can burn out if you over draw them, aftermarket alts usually have excessive diodes, like 12 50 amp, even its its a 250 amp alt. If this wire shorts, you will not only short the alternator but the battery, thats why its good to have a fuse for the wiring limits near the battery, you better at damaging your battery by running it empty, then to have it explode, thats how I see it at least
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Big 3 is
Thanks man
but yeah i already did alt pos to bat pos with a fuse and neg to ground i was just having some trouble finding a good spot for engine to ground
im going to try and bolt it to the casing of the alt and go straight to the battery
Wire: Knu 0 gauge
  • Who's Online   1 Member, 0 Anonymous, 1626 Guests (See full list)
