4 z V.3 18s 18v and a big 4th order
so the rear chamber is the sealed?
i wanted to mound them inverted so i didnt have to calculate woofer displacement in the sealed partition because im unsure of what the displacement actually is also how did you get 5-6 cubes the site says they work in .2-.3 cu ft sealed each .2*8=1.6 .3*8=2.4 so thats how i came up with 2 cu ft for the sealed
Yes the sealed chamber is the rear. My bad was thinking ported. Displacement with the 8's shouldn't be much, the 12's displacement is .14 so i would guess the 8 to be .1 - .12..
I personally would make it about 3.4 cubes before displacement putting you at right between 2 and 2.4 but it depends on how much power you plan to run whether you want to make it a little smaller or not.
ill help you with a 4th ...
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
thanks man
i plan on running dual 2 coils with 2 saz2500s so each set of 4 will be at 1 ohm
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
this is the first run of the 5ks i think, i wouldnt get them right way incase there are some bugs. im sure they did alot of testing, but still.
same amps as american bass 500.1s and the cactus amps.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
id do prolly a 3:1 ratio. .5 sealer per, so 4 cubes sealed, and 12 cubes ported with magnets inside of the ported section so you can smell them if they get stinky. and 168 - 180 square inches tuned to 45 hzish.
thats what i would do ...
make the selaed chamber smaller to handle more power or bigger to be more efficient.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
hey dwright27 would it be better to go with the style i came up with just mess with the tuning and volume or like the horn shape or whatever (not sure what its actually called) when the box is shaped like this |\/| i think you get the idea
i would do how you have it.
the V shape i would keep like 10 - 12 inches between the rear woofers.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
you can buy new cab corners.
This... Not a good Idea to mix glass and metal, especially in colder climates, because the metal and glass expand and contract at different rates, causing cracking...
ive been told it will last maybe 2-3 years
