SPL Gains!! Updates @page 30 (routing the port)
fecupe2001
good infor here man
Thanks a lot dude, wait for more to come very soon, routing the edges of a slot port, mdf bracing vs dowel, flaring a slot port with pvc, before/after resin, sanding the resin, aplying armor all inside of the box to make the resin even smoother, bondo on pvc roundovers and much more :)
good infor here man
again up to you but dowel vs them threaded screws just an idea
good infor here man
I thought about this one, but that will be later since the single 12" box doesn´t require any bracing, i will try that on a box for 2 12´s , i also want to try wiring the subs thru steel screws to make the connection outside the box wich is way more confortable, i wanna know if that drops your score a little bit vs wiring directly from the amp to the sub....
ummm what about if you have the negative runs to the front and add chassis grounds in the back?? if you have the wire??
I did thought about that, i honestly haven´t try it because of lazyness, maybe i will soon :)
Well, i was going to but i realized that my birthday it´s this saturday lol, so i guess i´ll be busy getting drunk the whole weekend, maybe next i will, there are a few other things that i wanna try out :)
A few Ideas you could try testing
Results so far!!
Gain:
- Negative wire run from battery to amp instead of grounding it to the car: 0.3 dbs(CCA wire vs OFC Wire)
- 2 extra batteries: 0.2 dbs (depend on the application, i was using SMALL power).(HO Alt vs Stock alt)
- Printing Vinyl inside the box to make it smooth: 0.4 dbs automotive paint (colors white vs black (Think heat IE cooler subs), gloss clear vs flat clear,
- Extertnal flare on an aeroport: 0.9 dbs Round vs oval vs Rectangle vs square
- Internal flare on aero port 0.7 See Above
- Duct tape around the sub: 0.25 dbs Silicone vs rubber gasket
- Using 8 gauge from sub to amp instead of a POS wire: 0.22 dbs again CCA vs OFC
- Cooling the cabin with the a/c: 0.45 dbs Wonder what dry ice would do here lol you could find your peak air temp
- Armor all the whole interior of the car: 0.06 dbs This I just had to laugh about
Lost
- Raising tuning: 0.3 dbs, this depends entirely on the car!!
- Installing 45´s on non pressure points of the box: 0.4 dbs this you could test by bracing displacement vs bracing style
- Having 2 round ports with different sizes: 0.5 dbs duh :lol:
- Printing vinyl outside the box: 0.3 dbs paint vs fiberglass
- Changing from PVC roundover to mdf 45´s : 0.2 dbs this you could try using all different types of high density things ie HDF (High Density Foam), hard wood.....
Like I said just a few ideas never know what would work better or worse.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
