SPL Gains!! Updates @page 30 (routing the port)
fecupe2001
my bad...
Well guys , i don´t have a picture or anything because i was lazy and it was dark also, i took out the POS box out of my friend´s mazda protege, and i rounded the edges of the hole on the second baffle where i flush mounted the pioneer sub, previous score was 140.3 dbs , new score after this round over process :)
i was just thinking of getting one to boost up my signal voltage a bit. It wouldnt hurt my #s either though would it?
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
Sorry, i missreaded i thought you were talking about a epicenter, what´s the current voltage you are getting to the amp?
the preouts are like 2v i think. the deck is a kenwood kdc mp345u
TEAM DC
Well, before buying any line driver, just measure the voltage you are gettin from your head unit, for me, 1.2-1.5 volts are more than ok :)
can i measure it with a dmm?
TEAM DC
Yes, you have to measure it with a DMM, disconnect the RCA from the sub´s amplifier input rca, set the HU volume where you always play it, take the negative of the dmm to the round base of the rca wire, take the positive of the dmm to the tip of the rca wire and set the DMM at ac volts 20 or the lowest you can set since you ain´t seeing more than 2v if you are lucky :)
PVC is pretty sticky , paint it on the inside and then polish/wax it supersmooth .
put the outer flare on a baffle for better airflow (different sizes can be tested) and secure the wood to the floor of the car against resonance of the port itself .
bracing the port on the outside for added structural strength could also help .
i got a few for you today.
gained .7 by gorilla taping off the sunroof. gained .3 by covering the rear speaker deck with cardboard to make it smooth and gorilla taping the whole thing and the edges.
TEAM DC
