How to put in an 2nd alt?
i didnt get an alt bracket. I made my own. and many alts will have a wire that is for the battery light in your car, you need this wire to be hooked up to an ignition power source with a resistor or light inline.
You're making little to no sense guy...no alternator bracket but you made one? Which would mean...you have an alternator bracket.
And wiring isn't even the issue here. A turbo is run off of expelled gas and pressure, so it would be a part of the exhaust system...an alternator is belt driven...
yeaah, that didnt make much sense, lol.
sorry on that guys
BLAZERs never came with a turbo, GMC typhoons and syclones did. and again it has nothing to do with the belt. You may however have a A/C bracket...
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
Subs: 2 T1 12's
no i have my a/c in it's on the bottom under the fan. hold on let me see if i can find my cam.to take a pic.
it's a powermater alt. and batts i have a yellow top in front and a kinkets 2400 hc in back.
What load is your amp seeing? ie 1ohm, 2 ohms, 4 ohms.
well it was doing 2ch/ at 1ohm each.
:face palm:
Thats why, im 99% sure that amps IS NOT stable at 1 OHM, and if it is its not going to be efficient at all.
Subs: 2 T1 12's
:face palm:
well the amp is stable to do so. well i heard that hifonics is not power hungy and not good but i have done a 148db with it.
You did 148DBeeezzz with that amp and 2 hifonics 15's? :orly3:
Audio control Mic? IF you did actually do 148 than good for you, but its un-likely.
Subs: 2 T1 12's
  • Who's Online   0 Members, 0 Anonymous, 935 Guests (See full list)
