I might have read it wrong, but say my preamp voltage is 5v would i set it to 5 on my amp?
Yes, that will give you 100% sub output at 100% head unit volume. BUT seeing as it is u only use %50-60 of your HU volume.. I would set the gain one notch higher, that is, 4 volts. BUT that's just me, people may argue etc... Mostly, if you ever hear distortion, or ur subs skip, then turn it back down a bit. and if you DO set ur gain around 4 volts, remember NOT to crank the volume on your HU past the 50-60% mark. All of this is what I personally would do... everyone will have different opinions.
So would i set it to the 5 or 0.5?
2002 Gmc Sierra 4x4
2 10" dual 2 ohm p3's
Custom box (34hz)
Kenwood eXcelon 1800 watt amp
Kennwood monitor
Polk Audio door speakers
Kenwood tweeters
Boston acoustics rear speakers
alpine 4 channel
If your head unit is putting out 5 volts, gain would be 5. if your head unit puts out 4 volts, gain would be 4. Head unit 3 volts, gain 3 volts... Etc..
SO if our HU puts out 5 volts, your gain should be set to 5 volts.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
Alright cool thanks man! Sorry for all the questions, just wanna get this through my head. :)
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
No problem man, that's what the forums for, we are all here to learn :good:
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
You do realize that that HU probably doesn't put out 5v unless maxed. ....
Well i dont plan on listening to it maxxed out thats for sure. I just saw a thing on the spcifications online that said Expandability Options:
* 3 Sets of 5V preamp outputs (front, rear, and subwoofer)
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
Set your HU to 25, gain the amp till you hear distortion and then back it down a pinky finger nail.
Bass boost 0, LPF 8O, Infrasonic filter 2hz below tuning.
Alright ill try both yours and osamios ways. Thanks :good:
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
^ I agree. It's not the BEST way to do it, but it's the easiest for you without a DMM. and it'll work. Just keep in mind, if you EVER hear distortion, back it down a bit. too much of that will damage your subs.
Also, I think you were closer to the correct number earlier when you said it's RCA pre-amp was 2 volts. but then you said 5 so i just went with it. I'd check just oneeee more time. make sure you have the right voltage in mind. Then again, if your just going to do it by ear, then it doesn't matter too much.
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
Yea ill go to the audio store and see if i can borrow it so it will be easier! To check the impedance on the subs do i put the DMM in the speaker terminals?
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
  • Who's Online   0 Members, 0 Anonymous, 7654 Guests (See full list)
