Hoecard Posted January 19, 2011 Report Posted January 19, 2011 I have a jeep cherokee sport with a uni-body. Should all my grounds (front bat, alt, rear bat, rear amp) be bolted to the "FRAME" or the inner body. To make this more understandable for my front battery ground i just mounted right next to the stock ground just with 1/0 guage. Same with the rear batt i just riped a little carpet up and grounded. should i actually drill a hole and go to the frame or would that not be worth my time? Also my rear amp is grouned to my rear batt neg post.
AMI CUSTOMS Posted January 19, 2011 Report Posted January 19, 2011 Run a ground from the front battery to the rear. That would be best. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
dereileak Posted January 19, 2011 Report Posted January 19, 2011 either one will work, if you want the best then do both, I made a 2.5 inch hole in my floor, not hard, and went right to the frame rail that goes to the front of my van, and I only loose .04 volts, thats really good, but if you have a second battery in the back it doesnt hurt to have a second run from the front battery to the back for the neg. It gives it a clear run back, thats whats important! 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Hoecard Posted January 20, 2011 Author Report Posted January 20, 2011 2.5 inch hole dam how many runs do you have through the floor? Ok so should i keep my ground that runs to the body now and just add another one to the frame, or remove the one now and just run it to the frame. I will also run the neg on front to the neg on back. One more quick question. Were would you guys run 2 runs of 0/1 guage to the back in a small as jeep. Under the carpet in the center or any better ideas?
