externally fused amp
im buying an AQ2200D and this is the first amp ive had that isnt internally fused (i currently have its little brother, the AQ1200D). i will dedicating a run of knu 1/0 wire for the amp, now my question is do i fuse 18" from the battery AND close to the amp..or will the fuse at the battery be sufficient? id like to just fuse near the battery if possible, id like to get away with the least amount of connections possible, but if i HAVE to fuse near the amp i will.
if you wanna be extra safe then 2 fuses, but its not necessary, you only need 2 fuses if you have 2 batterys or more if more batterys
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
thanks, im not too worried about being "extra safe" just plain old "safe" works for me, the 1/0 run is only like 6 or 7 feet feet long anyway, its just in an extended cab dakota.
By externally fused do you mean this amp has no fuses?
I'm not exactly a noob, but I've never heard of such.
yeah the amp has no onboard fusing, your suppose to provide the fusing via your power wire, alot of the bigger class D amps dont have fusing, ive just never used a bigger amp like this.
Sounds like something that could go very bad in the wrong hands.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
you guys are making it sound like you've never heard of an amp being externally fused... look at any high powered amp.. AQ2200D, AQ3500D, sundown saz1500D, saz2500D, saz3500D, and saz4500D, i could name more, but you get my point.
You need to put a fuse as close to the amp as possible on the power wire use an anl 250 or 200. And it will tell you in the paper work with the amp how they recommend it.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
