Mechman Alternators
240 amp large case conversion kit
135 amps by 700 rpm
Full output by 1800 rpm
Oversize rectifier
oversize terminals
overdrive pulley
Adjustable voltage boost module included STANDARD
Our unit is the physically largest unit that will fit, and will have much better low RPM output and durability than anything based on the OEM housing.
$549
Assuming that it is the same as a standard mainland US spec vehicle, there are no modifications necessary. It accepts the stock alternator plug, and bolts into the stock bracket. You will need to buy a slightly longer belt from the autoparts store however.
  • Who's Online   0 Members, 0 Anonymous, 1876 Guests (See full list)
