you have a lot to learn brotha!
Care to expand on that
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
Guest MegaloManiac
yea that definately helps
so technically i could have different sized woofers
say 15" for 10hz-90hz
10" from 90 to 150
6.5 from 150 to 250
then the highs
does that sound resonable to u?
well the sub(15") should play til about 50hz..playing subnotes
for a midbass, 10" is kinda big, 8" should be the biggest you'll want, playing at 51hz-250hz
then you have your midrange, a midrange doesnt need 6.5, 4" at most is wanted...even then its just to get a "wider" axis response. play them at 251 up to about 4k-6k
then your tweets crossed on up from there
keep in mind there are a bunch of other things to keep in mind, for instance placement will factor in the biggest part. Lots EQing may/will be required to get the desired sound. its hard work but in the end you should be quite satisfied
i was never plannin on doin this soon
but i want to have the best sound quality car ever
and each speaker size can hit a certain range of notes the best and loudest
and that is wut im lookin for
its different and very complicated but im not sure anyone has ever tried it
if ur still on here when im 40 ill show u exactly wut i mean lol
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Guest MegaloManiac
i'll be here for awhile ;)
but just a note the higher the frequency you go the less cone area you'll need. only reason why i mentioned some of the stuff was a bit big.
yea thats tru i have really researched it that much but its an idea
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
