It sounds to me that you have the ohm load to low and its making your amp unstable then it eventually goes into protect mode. If you keep doing this you will eventually fry the psu. Try wiring your subs to a 4ohm load and it shouldn't cut out like that.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Posted (edited)
its at a 4 ohm load. i chcked with a dmm. and the protect light has never come on.
Edited by VIP3R
2 Sundown Audio SA-10s
Box built by Speed of Sound
Kicker 1500.1
Infinity Ref 475a
Rockford Fosgate T1682c 6x8s
Pioneer Premier DEH-510UB
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
i do mention. when it pops...it fucking POPS. sometimes multiple times. and loud
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
Definitely sounds like an RCA problem, like your subs are grounding out, could be the HU...hopefully not the amp...
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
im really hoping its the headunit. im gonna try different RCAs..then if that fails do the grounding thing...
anyway to test if its the amp or not?
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
Just outta curiosity, have you checked your power wire fuse? Mine was doing that the other day, turned out the Scosche fuse holders don't like anything more than 50 amps. Fuse was crisp, and it was the right size (100A). Switched it over (finally) to my ANL holder, and worked like a charm.
POTATO!
i chcked it once before but ill check again.
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
