and now i know why. new project.
from the front, they are the same radio but i got one on ebay to play with and not be scared to dig in to it.
radio from my old tundra is what i will use.
Eclipse avn726e. Flash based nav, dvd, usb, built in bluetooth, ipod. etc
:woot:
DC.jpgDC POWER
:woot:
sounds like quite a project, what do you have in mind? making a Mdf dash piece and glassing it in is the was ive always done it
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
A/C control and radio sharing the same board is the only problem.
DC.jpgDC POWER
ouchy, that looks like quite a project right there, move the whole board if possible then just disable the screen? just enough to fit that h/u in there, or why not use a single din? might be easier to work with
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Moving the board is my plan. but i will have to move 6 buttons, the lcd, and a small ribbon cable. Honestly that would be simple. And there is no point for me to use a Single DIN if i going to do this im going all the way
DC.jpgDC POWER
tsx?
05??
tsx?
05??
04 tsx why? have you done one before :drinks:
DC.jpgDC POWER
alot easier to start with the bezel and controls from a model that came with factory navi..
sorry worng pic..
