i need a box design for a re sx 12" on a ap1500.1
here are the woofer specs Electrical Q Value -Qes: 0.32
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.30
Free Air Resonance -Fs: 30.6 Hz
Equivalent Compliance -Vas: 47.6 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 88.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Im unsure on alot of things but ...
i was thinking
30" wide
14.5" tall
15.375" deep
13" port height
3" port width
11.125" port length 1
20" port lenght 2
square port area 39
box volume 2.13^3
tuning freq 34
i also plan on 45ing all the corners
Vehicle: 1996 Chevy Prizm
Amplifiers: Dual Xpa6100(Sub)
Enclosure: BassWorks 2.5ish sealed
Mids/Highs: Polk 6.5"s and polk 4"s
Subwoofers: RockFord Fosgate 15"
Wire:8gauge
Future Upgrades:Amp, another 15" , Big #
opinions ? criticizm ?
Wire:8gauge
Nice sub
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
other designs ?
Wire:8gauge
With that much power, 2-2.25ft^3 is plenty big for daily. The SX can handle 1500, so might as well use it. Tune at 33hz and you're golden. If you want more exaggerated low-end in exchange for some output up higher, go 2.25-2.5ft^3 at 30hz.
You could also try a t-line.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
  • Who's Online   0 Members, 0 Anonymous, 488 Guests (See full list)
