iceman1575 Posted February 3, 2011 Report Posted February 3, 2011 Okay, so I have two sets of subwoofers. I have two Yamaha SW118V subwoofers, rated 600w program/1200w peak at 8 ohms. I also have two Peavey DTH Concert Sub II's that my friend gave me with fried baskets (soon to be replaced with 4 Black Widow baskets), rated at 1400w program/2800w peak at 4 ohms. I currently have a single EP2500, rated at 1200w per channel at 2 ohms, 750w at 4 ohms. I have been thinking about how to power all 4 speakers (technically 6, but yeah...). Right now, I can hook up 1 DTH and 1 SW118V to each channel and get a final load of 2.67 ohms. Or, I can do both SW118V's to one channel, giving about 1200w program at 4 ohms (although they can take MUCH more), and both DTH's to the other, giving about 2800w program rating at 2 ohms. I'd like to keep it all on one amp, if possible, and I'm looking at replacing the EP2500 with an XTi 6000, with limiters and gains set correctly. To ask in short, which would be a better question, one of each per channel or separated? I know, usually mixing & matching subs in car audio is a bad thing, but I've seen a few setups with mix-matched subs and they sounded alright. And unfortunately, these subs are all I have for now, and actually I don't mind them. They were built right, obviously, to last so long. POTATO!
korey_hofer Posted February 3, 2011 Report Posted February 3, 2011 you still want them to be separated but it's not as big of a deal basically you want the front main 2 the same, and the surrounds the same, but the 2 main and surrounds don't need to match I can explain it better in a little bit previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
iceman1575 Posted February 3, 2011 Author Report Posted February 3, 2011 you still want them to be separated but it's not as big of a deal basically you want the front main 2 the same, and the surrounds the same, but the 2 main and surrounds don't need to match I can explain it better in a little bit Well, this is mainly about subs, so "main" and "surround" don't really apply, I think. Haha POTATO!
korey_hofer Posted February 3, 2011 Report Posted February 3, 2011 I was thinking something else I wouldn't mix subs if I were you. I've never done it but I doubt it would be good previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
unsafe8989 Posted June 23, 2011 Report Posted June 23, 2011 hi I have to genesis gdj 1000 at 1000 watts peak and 520 watts program at 8 ohms and I have a marathon 6000 that runs 900 8 ohms 1800 4 ohms so I couple two together at 1040 watts 4 ohms good power but when I tried mixing a marathon dual 18 sub at 2400 watt progran and 4200 watt peak at 8 ohms with one genesis and had 2920 wats at 4 ohns on a xti 4000 and it powers 4 ohm 3020 watts so great power and when I get a song with 30 hertz one plays and other just flexes wort thing you can do and at high notes one plays good one doesnt
iceman1575 Posted June 24, 2011 Author Report Posted June 24, 2011 hi I have to genesis gdj 1000 at 1000 watts peak and 520 watts program at 8 ohms and I have a marathon 6000 that runs 900 8 ohms 1800 4 ohms so I couple two together at 1040 watts 4 ohms good power but when I tried mixing a marathon dual 18 sub at 2400 watt progran and 4200 watt peak at 8 ohms with one genesis and had 2920 wats at 4 ohns on a xti 4000 and it powers 4 ohm 3020 watts so great power and when I get a song with 30 hertz one plays and other just flexes wort thing you can do and at high notes one plays good one doesnt Okay? Get your own topic. Kthx. POTATO!
tonedeaf Posted June 24, 2011 Report Posted June 24, 2011 I'd hook same speakers together on the same channel...mixing speakers probably wouldn't go over too well I assume.
iceman1575 Posted June 24, 2011 Author Report Posted June 24, 2011 I'd hook same speakers together on the same channel...mixing speakers probably wouldn't go over too well I assume. Meh, already took care of this a LONG time ago POTATO!
