doughboi916 Posted September 8, 2007 Report Posted September 8, 2007 i have a box thats 3cu and i debating if i should use 2 3in ports or 1 4in port, also is 3 cu too small for a 15in BL?? i scrrrd that it wont hit as hard as i want it to?? also port area?? dont understand? the more the better? so im guessing the 4in port will work better??
Coolwazabi Posted September 8, 2007 Report Posted September 8, 2007 3 cubes will be too small... and generally u want 12-16" or port area per foot... that would be like if ur port was 16 high and 1 inch wide.. it would be 16"... but u wanna make it square as possible.. but i have no idea on aero ports...
doughboi916 Posted September 8, 2007 Author Report Posted September 8, 2007 fi says 2.8-4cu for the 15 BL? dont know what to do,
doughboi916 Posted September 8, 2007 Author Report Posted September 8, 2007 how would 2 4in ports work?
doughboi916 Posted September 8, 2007 Author Report Posted September 8, 2007 ne one wonna help a brotha out?
Derrick824 Posted September 9, 2007 Report Posted September 9, 2007 3ft will work but most people tend to favor 3.5ft. If you're going to use 4" ports you'll need at least two of them.
zaxfire69 Posted September 9, 2007 Report Posted September 9, 2007 I used 4 cuft @ 30hz..With my BL 15..It slammed real good..In fact if you lived near Mississippi you could drive down and get my old box...I don't need it
Guest MegaloManiac Posted September 9, 2007 Report Posted September 9, 2007 Scott reccomends 2.8 cubes @ 33hz...seems rather small though but if he recommends cant argue there
