fritosaregood Posted February 4, 2011 Report Share Posted February 4, 2011 I've always liked Audioque stuff, I know its high quality... and also I'm pretty sure the 1 18 and 2200 would be as loud as 8 HFi 12s... and I won't have to worry about killing it... Plus the wow factor like someone said above... Also its in my price range still... what about your other option of the 4 brutus subs, they will be 'louder' than the 18 if you have enough space. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
protocaster69 Posted February 4, 2011 Author Report Share Posted February 4, 2011 Its gonna be in an extended cab yota... I would wall it for 4 15s... with the 18 I was thinkin about stayin' below the back glass... I like the fact the AQ stuff can be repaired lol if I blow a hifonics I gotta buy another one... Given the brutus 15s are only like 100 bucks a peice... The 4 15s would also be about 100 bucks more expensive and I think the aq2200 would murder them... lol Quote Link to comment Share on other sites More sharing options...
fritosaregood Posted February 4, 2011 Report Share Posted February 4, 2011 Its gonna be in an extended cab yota... I would wall it for 4 15s... with the 18 I was thinkin about stayin' below the back glass... I like the fact the AQ stuff can be repaired lol if I blow a hifonics I gotta buy another one... Given the brutus 15s are only like 100 bucks a peice... The 4 15s would also be about 100 bucks more expensive and I think the aq2200 would murder them... lol nah, they wouldnt have any problems on that power, as for the 18, get the dual 2 so you can run at 1 ohm, running at .5 puts unneeded strain on your electrical Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
protocaster69 Posted February 4, 2011 Author Report Share Posted February 4, 2011 (edited) also 4 brutus 15s would stick me at 2 ohms cause they're dual 4s... As for Electrical I'm going to have a 60 amp alt and a 150 amp alt stock battery and an optima yellow top... probably 3 runs of 2g wire... Edited February 4, 2011 by protocaster69 Quote Link to comment Share on other sites More sharing options...
protocaster69 Posted February 4, 2011 Author Report Share Posted February 4, 2011 Next question... I'm probably going to get the 18... sub will have to be facing forward should I make it port up, port forward, or too the side? was thinking forward... amps on top of the box... Quote Link to comment Share on other sites More sharing options...
fritosaregood Posted February 4, 2011 Report Share Posted February 4, 2011 I would do port up, sub drivers side and port passenger side. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
