So i hav'nt been active on SMD, or any other forums in quite some time now... just been busy with working a lot and other things. So now my time has begun to slow down and i can finally get back into the swing of things. I didnt exactly get out of audio, just stayed low-key for the most part. Now i am seeing all over forums and facebook all these new audio brands i have never seen before lol
Here is the link to my first build with this car:
http://www.stevemeadedesigns.com/board/topic/150914-2012-scion-tc-build/
---it kinda died short... but as i said, i never really kept up on it. Figure'd i would start a new thread since i am doing a more involved build, all around. Not just on the audio side of things.
-Here are some updated shots of the car:
D96B562E-B1AC-49FA-9430-C871AF66871F_zps
E3DF31D4-EA0C-4893-A871-12A253C3C050_zps
Currently lowered on Eibach Sportline springs
Wheels are XXR530 (fake wheels FTMFW) 18x8.75 all around +33 offset in the front and +20 in the rear
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Sexy car, in for more pix
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Most recent setup consisted of the following:
Pioneer AVH-X5500BHS
2x Sundown SA-10s
Sundown Audio SAZ1500v.3
9E217AFB-83CF-43D2-83FA-3D56D9C37FC9_zps
It was a real nice setup. But got bored of it after a few months so i sold the amp and subs a few weeks ago. Also sold the 5500BHS and picked up a Sony MEX-600BT single din...
Team Sundown Audio
Last year I REALLY wanted to put an iPad mini in my dash, but never had the time to pull the trigger on starting it... well whenever i ran into some down time these past few weeks i started working on it.
Here is what my dash looked like when i started it:
e46c5b01-d4b4-45f0-9eec-5d367ed38e22_zps
Now, i couldnt decide if i wanted to keep, or delete the portion where the hazard switch and clock are.. So i did a couple mock ups:
However, as you can see... My hazard switch protrudes out of the dash, this made it somewhat difficult to work around and figure a way to get rid of this and create a new body line
So i decided to go the hard way and cut that whole top portion out, here is the dash tapped up for where i need to cut:
2EB6463D-9A09-46D0-81C7-FAC13304022C_zps
all rough cuts were made with an airsaw, any ridges i sanded down with my air side grinder, came in real handy having that in the long run
Team Sundown Audio
I used one of Doug's new side slider kits. I Actually was the first one to recieve the new kit, got it before they offically went on sale in November (yup, had it since then to force myself to go on with this project lol)
A39ACC68-AE97-4B8B-A128-3C2F95E2AB06_zps
Got the dash cut and trimmed to where i need it to be:
1F81DC41-E7B5-4C04-A7D0-F475505EB742_zps
Notice how far that hazard switch sticks out... I ended up completely cutting it out around where it is
I used a 2 part epoxy to bond the kit to the dash, and followed up with some fiberglass on the back for added support. These ipad dashes tend to crack after being removed in and out several times, so i want to add strength to the panel to limit that
7A1224E8-91DC-4561-A57F-CE1806A529DE_zps
Now here what i did was cut out the hazard switch and followed its shape. I then rough cut a small piece of ABS plastic. I heated it with a heat gun to give it the same dash curve that is already present on the rest of the panel, and glued it in. Didnt need to be 100% perfect as bodyfiller in later stages will take care of that:
028C33C8-2D62-4B08-AE80-8D192BAC9F65_zps
Team Sundown Audio
Small test fit to get a rough idea on how it is going to look
F1DE0097-77FA-468A-AFED-E4CFEE7BEC78_zps
The body filler i used for this is Sonus Matter, by Sonus Car Audio. Hands down the best filler i have used to date. Real great stuff here and pleased with how will it shaped and sanded down
I slowly build up my VERY low to begin with spots. Mainly where the ipad mount met the dash:
EB0A7884-92C2-4894-AC68-B9C3B29B6A16_zps
sanded it down and began to form so i could later apply more filler to the rest of the panel.
As you can probably tell i didnt quite work quick enough lol. Notice how i was able to lay down the right side a lot more smoother than the left. But it all sands the same! so i wasnt worried with the application:
00110BC3-212D-4D67-9846-647067BEE0EC_zps
so then i got to this point, had a couple pit holes, i actually sanded them down and out and applied a last layer of filler
A82D7117-EE38-472D-92DF-24CDB4EC1B74_zps
99806D53-F157-4782-90EA-DD131F16EBB8_zps
Team Sundown Audio
After i was sure i was done with the body filler and sanding, i laid down the first fresh coat of high build primer, after i sanded that with 220, i re-applied 2 coats of high build primer, sanded with 600 grit and then applied 2 coats of self etching primer.
Here is what it looked like after the high build primer:
7026048F-3254-45D8-B892-7A063EA9977B_zps
and then after my sanding and coats of self etching primer:
0456D24F-3501-4DA3-8CE7-3AB5F49A4F54_zps
I then wet sanded with my 600, applied one more coat of self etching primer, and here is where i currently am at with this:
349B1CC0-7755-4D50-9FBA-95CD0EF641FB_zps
5D24461E-6E0F-4C54-905B-390F7D02E983_zps
nice and smooth all around with 0 pitholes, cracks, or imperfections in the body work. I am pretty pleased with this outcome, by far. First time tackling a project like this, fabricating a dash piece, working with smaller pieces such as this is deffinatly more difficult IMO than a larger piece such as a door panel, geez.
I am currently at the stage where i have to decide on how to finish it, i kinda don't want to paint it.. but i might, was thinking vinyl, sude, or hydro dripping the piece.
Also, if you noticed previously, this original dash was textured. Notice i have completely gotten rid of that and made it smooth as can be. I am in the process of working on smoothing out the two matching, adjacent panels to look as so, so those will also need the same finishing. I couldnt leave them textured, it would bother me too much as it would make my smooth panel look out of place.
Team Sundown Audio
Damn that looks nice
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
thanks man, appreciate it
Looks good. Do mines next.
sure thing, gimme your dash and couple hundred bucks lol
Team Sundown Audio
  • Who's Online   1 Member, 0 Anonymous, 1540 Guests (See full list)
