rockFord_Expedition Posted April 11, 2014 Report Share Posted April 11, 2014 Because this is what he purchased and doesn't want to spend the money on a proper crimper. Soldering is cheap. Just need to practice with it a bit Ah, so you're not necessarily advising against crimping, you are against crimping the way he was/is going to do it. Gotcha. For a one time job soldering is cheaper for sure. My crimper will pay for it's self though. Ghetto crimp police in full force! Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
rooles Posted April 12, 2014 Author Report Share Posted April 12, 2014 Lolz ill post a pic later Link to comment Share on other sites More sharing options...
rooles Posted April 12, 2014 Author Report Share Posted April 12, 2014 Link to comment Share on other sites More sharing options...
rooles Posted April 13, 2014 Author Report Share Posted April 13, 2014 How should i proceed? I have received the hammer crimper Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 13, 2014 Report Share Posted April 13, 2014 See if you can sell it on craigslist or ebay. Or return it Here's a nice tutorial on soldering. You can cut yourself a chunk of wire to practice with. When you are done, heat up the terminal and pull it off with a pair of pliers, cut the wire back, and re-solder until you are comfortable http://www.stevemeadedesigns.com/board/topic/6399-how-to-solder-large-gauge-wire/ Biggest noob mistake I see with soldering is trying too hard to get a nice pretty pool of solder on top. I mean.... You could shoot for that if you want, but it doesn't really help anything. What you really want is penetration - you want the solder to wick into the strands. Note that I say into the strands, not into the wire. You just want it to wick into the part that's inside the terminal, not 3-4" past. Best way I've found is to use more heat. Heat up the lug, solder as fast as you can, then remove the heat. Idea is that you finish before the heat travels down the rest of the wire, carrying the solder with it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
rooles Posted April 13, 2014 Author Report Share Posted April 13, 2014 I have soldered much smaller wires before with a soldering iron. Ill have to look for a torch. Any suggestions on where i can buy a cheap one? How much are they? Link to comment Share on other sites More sharing options...
rooles Posted April 13, 2014 Author Report Share Posted April 13, 2014 Crimping copper ring terminals on heavy gauge bat…: Is this acceptable? Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted April 13, 2014 Report Share Posted April 13, 2014 His crimp is useless. The solder was adequate. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
rooles Posted April 13, 2014 Author Report Share Posted April 13, 2014 I will do the soldering tonight. Now i have a question about this bad boy should i use the front signals or the rear ones. And how do i set the gains? Link to comment Share on other sites More sharing options...
rooles Posted April 14, 2014 Author Report Share Posted April 14, 2014 Link to comment Share on other sites More sharing options...
