evermaxx Posted October 24, 2014 Report Share Posted October 24, 2014 Friend needs a box design 2 Massive Toro's I tried finding info on subs but can't find much for em. 30 w 16 h 24 d Subs & port forward. Thanks guys. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
CleanSierra Posted October 24, 2014 Report Share Posted October 24, 2014 Friend of mind is a Massive dealer. If you want specs, I can get them for you if you'd like. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
evermaxx Posted October 24, 2014 Author Report Share Posted October 24, 2014 That'd be nice. Friend of mine is a dealer but out of town for a week. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
Joe X Posted October 25, 2014 Report Share Posted October 25, 2014 Won't you specify the diameter? Link to comment Share on other sites More sharing options...
gally Posted October 25, 2014 Report Share Posted October 25, 2014 Subwoofer Series Toro (Massive Audio) Peak Power Handling 2400 watts RMS Power Handling 1200 watts Voice Coil(s) Dual Impedance (Per Voice Coil) 4 ohms Voice Coil Diameter 2.55" Sensitivity 84.7 dB Xmax (millimeters) 12.6 mm Subwoofer Design Round / Circle Woofer Composition Pressed Pulp Fiber Woofer Surround Rubber Magnet Structure Double Stacked Subwoofer Grille No Re-Cone Kit Available No Recommended Enclosure Specifications Recommended Enclosure Type Ported / VentedSealed Minimum Sealed Box Volume 1.80 cubic feet Optimum Sealed Box Volume Maximum Sealed Box Volume 1.80 cubic feet Minimum Ported Box Volume 3.5 cubic feet Optimum Ported Box Volume Maximum Ported Box Volume 3.50 cubic feet Top-Mount Depth 8-4/16" Cutout Diameter 13.90" Shallow Mount Installation No Electromechanical Parameters Free-Air Resonance (Fs) 35.7 Hz Equivalent Compliance (Vas) 59.668 liters Total Speaker Q Value (Qts) 0.839 Electrical Q Value (Qes) 1.422 Electrical Resistance of Voice Coil (Re) 3.60 ohms Mechanical Q Value (Qms) 2.046 specs 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
evermaxx Posted October 25, 2014 Author Report Share Posted October 25, 2014 Sorry about that. 12 in. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
RainStryke Posted October 25, 2014 Report Share Posted October 25, 2014 Not sure if you want the D2 or D4. Here is the PDF http://www.manualslib.com/manual/524835/Massive-Audio-Toro-104.html Link to comment Share on other sites More sharing options...
Joe X Posted October 26, 2014 Report Share Posted October 26, 2014 Based on the specsheet posted above (12D4 subs) here is a suggestion, power: to sub(s) rated, amp subsonic filter to 32Hz, minimum port clearance 4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
evermaxx Posted October 26, 2014 Author Report Share Posted October 26, 2014 Thanks a lot Joe. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
