What size fuse do I need???
SHOHARD
Hello everyone! I am new to the forum and want better understand everything better. Here is what I have so far.
2015 Ford Sho non-sony edition
Door speakers: ROCKFORD FOSGATE 6X9" PUNCH SERIES 4 WAY FULL RANGE SPEAKERS P1694
Center Speaker: ROCKFORD FOSGATE P132 3.5" 2-Way Punch Series Coaxial Car Speakers p132
Tweeters: ROCKFORD FOSGATE P1T-S PUNCH 1"
Amp to run components: Power Acoustik RZ4-2000D 2000 Watt 4-Channel Class D Car Audio Amplifie
  • 4 ohms: 160 watts x 4 chan.
  • 2 ohms: 250 watts x 4 chan
  • Bridged, 4 ohms: 500 x 2 chan.
  • Max power output: 2000 watts x 2 chan
Subwoofer: 12" Kicker CompVR 07CVR124 with dual 4-ohm voice coils
  • dual 4-ohm voice coils
  • power handling: 50-400 watts RMS (200 watts per coil)
  • 800 watts peak power handling
  • frequency response: 25-500 Hz
  • sensitivity: 86.7 dB
Amp for Sub: Not sure what I want yet. Need suggestions???
Amp wiring kit: KnuKonceptz KCA 4 Gauge TRUE 4 Gauge
Installation Kit includes:
  • 18 Feet 4 Gauge Ultra Flex Blue KCA Power Wire
  • 3 Feet 4 Gauge Ultra Flex Black KCA Ground Wire
  • One inline fuse holder with 80A AGU Fuse
  • One 17 Foot Black Bassik RCA Cable with Built in Turn On lead
  • 20 Feet TCA Clear 14 Gauge Tinned CCA Speaker Wire
  • 2 Gold Plated 4 Gauge Ring Terminals, 2 Gold Plated 4 Gauge Spade Terminals
  • Wire ties and grommets
KCA Kable 4 Gauge Spec:
  • KCA Kable Power / Ground Wire consists of oversized, 34 gauge stranded, copper clad aluminum (CCA) conductors
  • Maximum load @ 20 feet - 100A
  • Outer diameter - 11mm, Conductor diameter ~8mm
Distribution block: 4 Gauge Input Mini ANL Distribution Block 2x 4 Ga Output Audio In Out AWG Power
First question: What amp should I get for my sub?
Second Question: What size fuse do I need for my distribution block?
Thanks in advance for your help.
Iirc 4 awg is to small just for your 4 channel let alone another amp
Sarcasm alert!!!
someone (wouldnt know who)forgot cheap amps rate max not rms
Sarcasm alert over
But still you will likely need a larger power wire
Example: 60 amps (the 2 30amps fuses on the 4channel) + 50 amps (rf prime 500 watt used for example) = 110 amps which is over the 100 amps rated for the 4ga. (Granted not much over but over)
If you were to upgrade your 4 channel you would likely be way over the limit of the 4ga
Example: (rf 600-4d) 100 amps + 50 amps (rf monoblock) = 150 amps which is well over the rating for the wire
Not trying to sound rude just doing this in a hurry (at work on break)
If you're wanting to go with a 4 gauge kit from Knu, get the OFC kit like this one:
http://www.knukonceptz.com/mobile-audio/amp-installation-kits/sp/complete-4-gauge-amplifier-installation-kit/
It's $20 more but will have the extra current carrying capability that you will need.
Damn I wish I knew that before I bought the one I have.
You like rockford based on the majority of your equipment. Have you looked at the rockford prime 500.1 or a kicker dx500.1?
I just read the reviews and the ones I got were second best of the 2015 speakers. But I want a small amp that I can place under the seat that will punch good.
Damn this sucks to hear.
Sarcasm alert!!!
Sarcasm alert over
So overall I need a different 4 channel amp and a larger wire kit. Damn This is not what I wanted to hear. But I need to do better at my research I guess. Clownrock95 what amps should I look at getting? I want them to be small so I can hid them. Or should I go with a 5 channel?
If you want small and efficient and can fit these in your budget this is what I would get.
Sub amp
http://www.rockfordfosgate.com/products/details/t500x1br
Mid's and highs amp.
http://www.rockfordfosgate.com/products/details/t400x4ad
Sarcasm alert!!!
Sarcasm alert over
Not sure if your gona find a 5 channel with enough power to get the full potential out of your speakers my suggestion would be as follows
Get a better power wire wire (http://www.knukonceptz.com/mobile-audio/amp-installation-kits/sp/kolossus-fleks-4-gauge-amplifier-installation-kit/)
Buy the monoblock broke suggested but keep the 4ch for now
Install everything
When your bank account recovers get the 4 channel suggested by broke if you feel you need the extra sound
Iirc nvx has some small foot print amps might look at those if you don't like the fosgate ones
  • Who's Online   0 Members, 0 Anonymous, 1549 Guests (See full list)
